newby needs help ..smiley face electrical poblem
Postby 1agos » Thu Feb 16, 2006 9:39 pm
My 2.5d van starts up first time everytime but the wipers heater and head lights do not work imediatly but start working after about a minute. This is an intermitant problem at the moment but seems to be happening more regularly. Also sometimes I do not have any dash warning lights but the engine still fires up. The van is an x BT with 46000 on the clock.
Any help would be appriciated
Andy
1agos
Postby 24vMk2 » Thu Feb 16, 2006 9:47 pm
Had the same problem on my sierra, was the main ingition relay playing up, changed it, no problem since :)
Can't remember which one it is on a transit tho!
24vMk2
Postby MrMPuk » Thu Feb 16, 2006 9:48 pm
Check the main fuse box next to the battery, it has the main power fuses in it, you may well have a bad connection in there due to the ingress of water.
I wouldn't noramlly say this but as so many things seem not to work I would start there.
Postby 1agos » Thu Feb 16, 2006 10:01 pm
What a great site this is very quick replies. Thanks lads will check both these and let you know. :D
1agos
electric probs
Postby johnhooper » Mon Feb 20, 2006 9:08 pm
I had electrical problems with my tranny (M reg) It turned out to be the connecting block on the steering column, contacts were corroded and getting very hot! I chopped out the connector block and re connected all the wires using bullet connectors, no problems since
For airbrush artwork check out http://www.killerpaint.co.uk
johnhooper
Postby crazyscoot » Mon Feb 20, 2006 11:27 pm
dodgy Alternator?
Negative reality inversion
crazyscoot
Postby 1agos » Wed Feb 22, 2006 9:16 pm
thanks all . Fitted a new ignition relay and the problem has been resolved.
what a result :P :D
1agos
