Checking this £2.50 bolt could save you £500!!
Postby Bulletguy » Sat Jun 21, 2008 5:29 pm
Fanbelt recently broke in my '93 Transit Camper.
After fitting a new one i noticed the alternator pulley appeared out of alignment. My eyesight not being what it once was i took it to a local Ford mechanic for a second opinion.
"Bottom bolts f***ed....common Transit problem", he instantly declared. A new bolt costs £2.50.....but that was only the beginning!
The hole through the two plates the alternator is attached to by the bottom bolt had worn into an oval 'egg shape'. So not only was the bolt scrap, but also these two plates....£25 and £140 respectively.
To replace both plates is a cambelt off job so new cambelt had to be fitted. As the alternator was pretty much shot i decided to have that replaced at the same time.
Total inc. 4 hrs labour? £500.......and all because a £2.50 bolt was not regularly kept tight! Amazingly the bolt is just 8mm diam which i thought pretty crazy given the amount of vibration from a diesel engine. The bolt used for the same purpose on a Mini is much more substantial.
I excuse myself by not owning the van very long and only discovering it due to the fanbelt snapping. OK i could have saved myself £120 if i'd done the work myself, but my 'mechanicing days' are long over now and as i'm just about to embark on a lengthy tour through Europe, i'm glad it happened here and not 'out in the middle of nowhere'!!
Bulletguy
Re: Checking this £2.50 bolt could save you £500!!
Postby Guy88 » Sat Jun 21, 2008 5:43 pm
On my MK5 i drilled the hole out and fitted a UNC bolt :D
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby motorwise » Sat Jun 21, 2008 6:39 pm
very common fault I'm afraid
http://www.motorwise.net
motorwise
Postby Bulletguy » Sat Jun 21, 2008 7:18 pm
Guy88 wrote:On my MK5 i drilled the hole out and fitted a UNC bolt :D
That was the mechanics original intention....until the bolt came out and the 'hole' showing. It had almost gone through.
There was simply no metal left to drill!!
Bulletguy
Postby Bulletguy » Sat Jun 21, 2008 7:22 pm
motorwise wrote:very common fault I'm afraid
So i was informed. He'd seen it many times over the years but as he said, as long as it's kept tight it's ok.....but it's often neglected until its too late.
Surprised Ford didn't make the nut at the back 'captive'. At least it's then only a one handed job!
Bulletguy
Postby motorwise » Sat Jun 21, 2008 9:31 pm
it's a self locking nut - but people don't lock 'em up tight when they have 'em apart - you're probably right though a captive nut might have removed the temptation not to pull it tight if it's a one spanner job instead of two - Di's are out of production now (and in the london area soon will definately be a thing of the past) so I don't suppose it matters much anymore :wink:
motorwise
Postby Bulletguy » Sat Jun 21, 2008 9:51 pm
motorwise wrote:it's a self locking nut - but people don't lock 'em up tight when they have 'em apart - you're probably right though a captive nut might have removed the temptation not to pull it tight if it's a one spanner job instead of two - Di's are out of production now (and in the london area soon will definately be a thing of the past) so I don't suppose it matters much anymore :wink:
If by self locking you mean 'nyloc' then they are fine.....but should be renewed once taken off as the nylon inner loses its ability to lock. A captive nut would have made the job simpler but i suppose Ford were counting the farthings!
Yep....I know the DI is virtually a 'thing of the past'......but then not only will it happily cruise at 60-70 (ample for a high top Campervan)....it returns 40+mpg even when fully loaded!
Bulletguy
Re: 40 MPG???????????????
Postby HiCube4 » Sun Jun 29, 2008 11:06 am
'Ere what colour is the sky on your planet mate? 40 mpg is a little optimistic i would have thought!
HiCube4
Postby FredTransit » Mon Jun 30, 2008 3:38 pm
HiCube4 wrote:'Ere what colour is the sky on your planet mate? 40 mpg is a little optimistic i would have thought!
is this reply in the right thread?
FredTransit
Mk2 Trannyist
Postby MrMPuk » Mon Jun 30, 2008 9:39 pm
No, he's reply to the guy above his post.
Postby Luke » Mon Jun 30, 2008 10:08 pm
mines not a high top but on a steady motorway run i get over 40 mpg :D
Postby clobryn » Tue Jul 01, 2008 10:06 am
Thanks for the head up Bulletguy
clobryn
Return to Transit Talk
