transitgeoff wrote:whats going through my head is pump timing, even though i pinned the pump, cams and flywheel, loosened the bolts on the timing gears so that the chain could tension right roundthe filter head is only a month old fitted by a dealer, when i changed the pump i cleaned it and blew it through with me airline, could that of damaged it
when its warm it seams ok but i still think it has a very slight hesitation on reving up,and when letting the revs off it seams to drop just below its tickover level then pick back up to tickover, the bloody thing is annoying me now
but i never learn, i should have just changed the whole engine in the first place
