What engine should I choose?
Re: What engine should I choose?
Postby Preiss » Tue Jul 01, 2008 8:21 pm
My engine, what type?
Preiss
Postby FFP » Sun Jul 06, 2008 12:04 pm
instal a vw engine, ford makes great cars but engine wise, there not at the top.....( sorry guys but siames port pushrod v6 engines ain't great)
you can keep your flat petrol front pannel and original gearbox if you want (only change to the van is a cut out and lowered front engine suspension beam to clear original vw sump)
al 4 cyl vw engines share the same bolt patron, so everything from a 2.0 8v or 16v to a vr6 or 1.8 20vt engine
i'v started with a 1.6 gtd engine and now installed a 81 kw tdi engine does 15km/liter, dont know what that is in mpg
plenty power with 110hp standard and 235 nm, now looking for longer rear axle ratio.
belhouse conversion is pretty simple without extensive machining i mailed some pictures to the forum keeper and can give some instructions
if you want to change to diesel frontpannel you van fit anything....
gr Marc
dont buy it, build it
FFP
Postby FredTransit » Mon Jul 07, 2008 2:13 pm
If you are going to go into mods, just mod the firewall and put in a pinto. It can be done, and you will keep the flat front.
FredTransit
Mk2 Trannyist
Postby madmark » Mon Jul 07, 2008 2:43 pm
preiss as knowbody has answerd your question ,you have a essex v4 engine! :wink: :wink:
Postby FredTransit » Mon Jul 07, 2008 3:01 pm
What's the difference between the essex and the cologne?
FredTransit
Mk2 Trannyist
Postby madmark » Mon Jul 07, 2008 6:36 pm
cologne is 1688cc
Postby FredTransit » Tue Jul 08, 2008 2:39 pm
Yeah I knew that, it's the German engine. I mean how do you tell visually?
FredTransit
Mk2 Trannyist
Postby Preiss » Thu Jul 10, 2008 8:01 pm
madmark wrote:preiss as knowbody has answerd your question ,you have a essex v4 engine! :wink: :wink:
Thanks for the answer. But I need to know which one of the essex it is to?
How many litres it is. Can you see it or do you need more information?
Preiss
Postby bron y aur » Thu Jul 10, 2008 11:20 pm
You hav'nt scratched the surface with the engine you already have, try tuning it before you condemn it, it probably is a 1700cc though needing a bit of t.l.c. :wink:
i started with nothing, still have most of it left
bron y aur
Postby FredTransit » Fri Jul 11, 2008 12:36 pm
madmark said it was the essex V4, so it will be a 2L.
FredTransit
Mk2 Trannyist
Postby duncr » Mon Jul 14, 2008 8:06 am
FredTransit wrote:Yeah I knew that, it's the German engine. I mean how do you tell visually?
Essex, dizzy at nthe front
Cologne, Dizzy at the rear
also a 5 speed type 9 box bolts on to an Essex, so that is an option
Daily transport !!! as my other cars are .....................F**KED
duncr
Postby Guy88 » Mon Jul 14, 2008 8:57 am
essex has 2 exhaust ports,
cologne has 1
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Sundowner » Mon Jul 14, 2008 11:22 am
put a 460 in there
Its a bolt in job and you can use the factory v4 gear box and plus the 460 is very economical :wink:
Yeah i know its big green and rusty so move your Porsche before i bash it with 460 cubes of fords finest cast iron
Sundowner
Postby FredTransit » Mon Jul 14, 2008 1:55 pm
You sure? Do the 4 pots have a different flywheel to the 6 pot? Cos I didn't think you could have a 5 speed at all on an essex. Not that it matters, I wouldn't want a type9 again.
FredTransit
Mk2 Trannyist
Postby TransitNorth » Wed Jul 16, 2008 6:22 pm
Hi! My firt post here so bear with me! ;)
I´m considering buying a Transit Mk2 to use as a transport vehicle for my Escort mk2 Zakspeed replica.
Found this Mk2 -76 with an Essex engine that have had the timing gear smashed. Owner drove it too long without replacing it...
I wonder if the Essex V4 is a non interference engine or do I have to rebuild the top and change the valves too?
Im not really in the mood for engine transplants or any heavy duty engine overhauls as all my energy and money are currently spent on the Escort... ;)
Still, as Transits without rust is pretty uniqe and this one is almost 100% rust free I would really LOVE to hear that this engine is a non interference... :D
And if it is, where do I buy new timing gears? The Ford dealer here thought I was joking when asking about a Transit that old!! :lol:
Regards; Roger
Roger Gustafsson
Escort mk2
Transit mk2 (soon to be?)
TransitNorth
Return to Mk 1 & 2
