a biger jack for a transit
Postby intransit89 » Wed Jul 09, 2008 12:11 am
hello seeing as i got some cash spare for a jack what would i get for 80.00 as i want a bigger one as them 20.00 jobbys not up to the job on a van :wink:
have been to my local car shop and thay have one like this
its a sealy 3ton trolley jack with 490mm hight and it has a foot pedel so when you press it down the jack goes just where you want to start jacking if you get me
its at 80.00 odd with V.A.T :wink:
might treat my self to some racket 3ton axel stands :wink:
so looking at 100.00 for the lot with vat included
so what you think to sealey brand then? before i get one
its not far of this one http://www.tooled-up.com/Product.asp?PI ... rer=NexTag
intransit89
Re: a biger jack for a transit
Postby MrMPuk » Wed Jul 09, 2008 12:15 am
Nothing wrong with Sealey, lots of workshops use them.
Postby BigNeil » Wed Jul 09, 2008 12:16 am
pump jack from machine mart not do you ?
trolley jack ??
BigNeil
Postby Jezclayton » Wed Jul 09, 2008 12:18 am
What's this? A new thread?
Sealy are good, but for the number of times you are going to use it a Halfords jack might work just as well. Alternatively, there is eBay of course. I do believe you are acquainted. :lol:
Transit Connect 2019 1.5 Tdci EcoBlue
Jezclayton
GLX Posse
Postby intransit89 » Wed Jul 09, 2008 12:19 am
MrMPuk wrote:Nothing wrong with Sealey, lots of workshops use them.
ok thanks mike so there not bad then?
its only the smaller jacks sh*t me up as other day as when i used to to jack my van up as you have to make the jack on its last jack up and it starts to look un safe ie one side tips of the floor :shock:
so looks like i be ordering one tomorow then
its got a foot pedel as i say for riseing it quicker if you get me
and is 490 mm quite high for a transit? so should do its job 8)
intransit89
Postby MrMPuk » Wed Jul 09, 2008 12:23 am
intransit89 wrote:its only the smaller jacks sh*t me up as other day as when i used to to jack my van up as you have to make the jack on its last jack up and it starts to look un safe ie one side tips of the floor :shock:
Sounds more like the way you are using it.
Postby intransit89 » Wed Jul 09, 2008 12:25 am
thay have these to at the local carshop for 15.00 + vat
http://cgi.ebay.co.uk/Three-Tonne-Axle- ... dZViewItem
wounder what width of a transit is for when i do ever get a Sealey Cross Beam Adaptor 2ton :?:
intransit89
Postby intransit89 » Wed Jul 09, 2008 12:26 am
nope even tryed wood etc to make it level still does it :?
but will jack a car up ok :wink: :?
intransit89
Postby MrMPuk » Wed Jul 09, 2008 12:27 am
Are you jacking up from the side rather than front or back?
Postby intransit89 » Wed Jul 09, 2008 12:31 am
MrMPuk wrote:Are you jacking up from the side rather than front or back?
only once but it even does it jacking the front end where the wish bone is :wink: maybe one of the wheels are fooked but hay i will just get a heavy duty jack :wink:
intransit89
Postby LSi » Wed Jul 09, 2008 10:16 am
Sealey are good tools, I use their lifting and supporting equpiment and have never had a problem with them, nor Draper.
I have to say though, as I find the standard jack awkward for Transits, I have a 2t Halfords trolly jack that's more than capable of lifting the van, I don't have any problems with it leaning. The jack itself may be flat and on the level but is the van?
If the van's on the piss, then that may cause the jack to be doing things you don't want.
LSi
Postby FredTransit » Wed Jul 09, 2008 12:01 pm
I got a little 2T trolley jack for changing wheels, does the job for £15 but I wouldn't want to do anything more involved with it. When you have a flat you have to jack up under the spring on the front though as it won't fit under the axle. You won't have that trouble though.
FredTransit
Mk2 Trannyist
Postby Terry » Wed Jul 09, 2008 6:33 pm
I changed a wheel with the standard Ford jack ONCE.
Then went out and bought a trolley jack, £30 from Machine Mart/Clarkes
changed 2 wheels since, and its fine. Even got a small bottle jack for the car.
Those scissor jacks scare me.
Pallet Puller
Terry
Postby intransit89 » Thu Jul 10, 2008 2:51 am
Terry wrote:I changed a wheel with the standard Ford jack ONCE.
had fun with them scissor jacks :lol: on a car you use to put it under the sill where there was a cut out on the side skirts and the scissor jack use to go tho the sills :lol: rusty :wink:
intransit89
Postby MinorMatt » Thu Jul 10, 2008 7:24 pm
I've had no problems with the ford scissor jack... but you have to use the jacking points and be on a flat level surface.
I carry a 6 ton machine mart bottle jack in the van (about £25 I think) which also lifts the van easily!
Return to Transit Talk
