transmission oil.......how much!!!
Postby piperdog » Sat Feb 25, 2006 6:12 pm
hello,can you help...my rear diff has decided to leak oil {coming from the wheel )is there an alternative to fords oil and will anything bad happen if i put 90 in ...thanks tony
piperdog
Re: transmission oil.......how much!!!
Postby Luke » Sat Feb 25, 2006 6:16 pm
taken from nighthawks answer in another thread!! :D
nighthawk wrote:A specific oil was used in the Transits RWD axle, any non ford oils should meet WSL-M2C192-A
The correct oil is thinner than EP90
btw no need to ask the question twice - i'll delete the other one!! :D
Postby piperdog » Sat Feb 25, 2006 6:22 pm
thanks for the quick reply.....my local ford hasnt got any in stock and the van is needed for monday ,does any know if putting in 90 will cause trouble
piperdog
Postby madmark » Sat Feb 25, 2006 6:36 pm
go to any store ,ep90 is what you want! :)
Postby piperdog » Sat Feb 25, 2006 6:39 pm
:) thanks ,thats sown that up,im now going to post another thread on th art of changing the seal
piperdog
Postby Nighthawk » Sun Feb 26, 2006 8:06 pm
EP 90 is much thicker than the correct oil.
When you say it's leaking at the wheel end of the axle, what vehicle do you have ?
Type 51 single wheel or Type 53 dual wheel ?
Depending on which axle it is, the method of replacing the failed seal is different.
On one axle it's fitted into the axle tube and on the other it's in the hub.
Nighthawk
Postby gemini » Sun Feb 26, 2006 8:18 pm
manual says
hypoid ford spec SRM2C-9102-A
gear oil ep85-90 (GL5)
gemini
Postby piperdog » Sun Feb 26, 2006 8:24 pm
its a twin wheel ,rear wheel drive
piperdog
Postby piperdog » Sun Feb 26, 2006 8:27 pm
ref. the oil is that for a 51 model ,thanks
piperdog
Postby Nighthawk » Sun Feb 26, 2006 9:52 pm
Twin wheel is an easy repair, there are 2 seals inside the rear hub, the inner bearing is a greased item and the outer bearing is fed with diff oil which travels along the ½ shaft.
The oil is held back by the smaller seal between the 2 bearings, it's often overlooked when repairing the hub as people are un aware of it's presence.
Nighthawk
Postby piperdog » Sun Feb 26, 2006 10:19 pm
:D thanks for that ,pardon my ignorance,so i guess i take off the wheel hub,remove the shoes ?and the half shaft and then
piperdog
Postby Nighthawk » Sun Feb 26, 2006 10:52 pm
The shoes can be replaced with the hub in place, but if the axle has leaked oil, the hub must come off.
Mark the wheels in relation to the hub and also mark the drum, putting them back in the place they came off will greatly reduce the chances of brake judder.
the ½ shaft will come out when you undo the bolts, the drum will* slide off the hub.
with the drum off and the shaft out, you'll need a BIG socket to undo the nuts, once the nuts and the locking tab are off the hub will slide off the axle tube.
replace the seals and make sure everything is clean, re build the lot making sure to set the preload on the bearings correctly.
Jobs a good un :D
* the drum might be tight to get off, a couple of clacks with a large hammer will usually do it, if your unlucky though, you'll need to adjust the shoes down to enable the drum to slide free.
If you have little mechanical experience, let a garage do it. Brakes aren't the right thing to take a guess on. and if you overtighten the bearings, it'll chuck it's hand in very quickly.
Nighthawk
Postby piperdog » Sun Feb 26, 2006 11:02 pm
BIG THANKS :D im going to do it saturday, as i clock up about 800-1000 a week , ill keep an eye on the level...hope its not too big a leak
piperdog
Postby piperdog » Sun Feb 26, 2006 11:04 pm
forgot to ask
back to origonal post ,can you agree topping up with 90 will be ok ?
piperdog
Postby Nighthawk » Mon Feb 27, 2006 9:02 pm
I can only advise the use of the correct ford oil m8, i hope you can understand that :)
If halfords, autoparts or any other motorfactor give you different oil thats fine :wink:
Nighthawk
Users browsing this forum: ColinK
