Mk1
Mk1
Postby zien49 » Wed Aug 06, 2008 8:48 am
Hi, All. Will all the running gear from a Mk4 fit in to a Mk1 with a diesel front? DEREK
zien49
Re: Mk1
Postby FredTransit » Wed Aug 06, 2008 11:37 am
I think the Mk4 has IFS, so it can be fitted but it's a bit of work. The engine will fit easily with the right mounts, and so will the box as long as you have the crossmember and cut a new hole in the floor for the gearleaver if it's an MT75 5 speed. You also need the prop shaft.
FredTransit
Mk2 Trannyist
Re: Mk1
Postby Neil » Wed Aug 06, 2008 12:44 pm
no :!: :!: you ll ruin it :!: its to good for that :wink:
Neil v6
Neil
Re: Mk1
Postby zien49 » Wed Aug 06, 2008 4:21 pm
Hi, Fred. What is a IFS? DEREK
zien49
Re: Mk1
Postby Luke » Wed Aug 06, 2008 4:44 pm
derek - it's not a strait forward fit mk4 has rack and pinion steering and ifs is indipendant front suspention!
just fit the Di and box :idea:
Re: Mk1
Postby FredTransit » Wed Aug 06, 2008 4:44 pm
Independent Front Suspension. The Mk1 and Mk2 had a beam axle up front. The two are totally different.
FredTransit
Mk2 Trannyist
Re: Mk1
Postby Neil » Wed Aug 06, 2008 5:08 pm
if its your green one leave it alone ,standard is worth more
Neil v6
Neil
Re: Mk1
Postby Luke » Wed Aug 06, 2008 6:36 pm
Neil wrote:if its your green one leave it alone ,standard is worth more
how do you know :? how many ifs mk1's do you know of that have sold :?: the only one i know sold for more becasue it was ifs :!:
Re: Mk1
Postby Neil » Wed Aug 06, 2008 10:46 pm
just my opinion :!: :!: thats what a forums about innit opinions :?:
Neil v6
Neil
Re: Mk1
Postby Luke » Wed Aug 06, 2008 10:52 pm
Neil wrote:just my opinion :!: :!: thats what a forums about innit opinions :?:
thats ok then :wink:
just when i get my fire van i intend to ifs it - was a bit worried i'd be devaluing it :lol:
Re: Mk1
Postby Neil » Wed Aug 06, 2008 10:56 pm
if i had the choice of a fire van and derecks it would be derecks i was lookiong round it in march 69 swb genuine automatic show me another :wink:
Neil v6
Neil
Re: Mk1
Postby Luke » Wed Aug 06, 2008 11:03 pm
yep i agree its a tidy van - seen it myself :D
Re: Mk1
Postby zien49 » Thu Aug 07, 2008 8:10 am
I All, When I say the running gear I mean the engine gearbox and prop shaft.DEREK
zien49
Re: Mk1
Postby FredTransit » Thu Aug 07, 2008 12:10 pm
Well that won't be too difficult to fit, the floor would need cutting for the MT75 though, and I think you will need to grind off the old gearbox mounts as the MT fits using a crossmember.
FredTransit
Mk2 Trannyist
Re: Mk1
Postby Neil » Thu Aug 07, 2008 5:19 pm
if you start cutting holes in it it will de value it, in my opinion
Neil v6
Neil
Return to Mk 1 & 2
