v8 in a mk11
Re: v8 in a mk11
Postby hitman » Sat Aug 09, 2008 9:19 pm
spitfire wrote:One maniac car builder has putted a mid mounted Twin Turbo V8 with over 1000 HP into a Transporter so the swb should do awright :D
Ketil
any more info on this or a link :D
hitman
Re: v8 in a mk11
Postby Steve4x4 » Sat Aug 09, 2008 10:01 pm
If you changed the rear axle for an independant set up the propshaft wouldn't be such a problem. You could a jag rear end or something newer like a Scorpio perhaps.
Some high ground clearance 4x4 vehicles use wierd diff set ups that would make the propshaft higher but the ratios probably wouldn't work.
If you used a transaxle you could build something using Scorpio trailing arms just without the diff in the middle.
Steve4x4
Re: v8 in a mk11
Postby sidspop » Sat Aug 09, 2008 10:21 pm
Yes is the simple answer.
It all depends on your creativity, and size of wallet.
A big block will generate oodles of torque, so you will need to uprate the rear end, as suggested an IRS is nice, or at least a 9".
If going down the IRS route, as I am doing with one of my Thames, the gearbox can feed straight onto the diff, because the diff is fixed.
If you are mid mounting, you will need either an autobox, or a degree in engineering to work out how to do linkages on a manual.
So all in all an auto is a better option, and not so hard on the diff.
You would also find an IRS has a much better ratio in terms of usability, and economy than trying to use a Transit diff.
In effect, get the block hanging on a cradle, gearbox on another. You then may have a small problem with cooling. Pipes need running from block to rad, and that sounds easy, but you may need an externa;l pump, in order to shove water greater distance.
If I can find the pictures on my other hard drive, I'll post them on how I am doing it.
sidspop
Location: The Black Country (near to Brummagem, but not the same)
Re: v8 in a mk11
Postby sidspop » Sat Aug 09, 2008 10:25 pm
Luke wrote: i actually measured it up and did some drawings etc. :mrgreen:
Bloody hell Luke, that's getting technical aint it?
sidspop
Re: v8 in a mk11
Postby spitfire » Sun Aug 10, 2008 10:28 am
Ketil
Try to find it :D
Ketil
Ketil
Norway
ketil.frengen@norgespost.no
2,9 Cosworth V6 1968 mod LWB Twin wheeler
viewtopic.php?f=27&t=49610
spitfire
Re: v8 in a mk11
Postby spitfire » Sun Aug 10, 2008 6:55 pm
spitfire wrote:
Ketil
Try to find it :D
Ketil
1105HP and 1311Newton Torque :D
Here is a link to the car
http://www.vwbus.no/index.html
:D Ketil :D
Ketil
Norway
spitfire
Re: v8 in a mk11
Postby Luke » Sun Aug 10, 2008 7:36 pm
thats very nice 8) 8) shame about the badge :lol:
the drawings i did had the engine virtually under the drivers seat - you can see in that pic just how low it sits :D
Return to Transit Talk
