Tyre Pressure
Tyre Pressure
Postby Aztran » Mon Feb 27, 2006 5:41 pm
Rear/ Front........
Does it vary with different tyres and what pressures do u use?
2000 x, new style Transit 350!
Aztran
Postby Transit-Tricky » Mon Feb 27, 2006 8:29 pm
According to my Haynes Manual, it varies with models, tyres and payloads. My Minibus is 50 front & 53 rear for 8 ply's. Check the manual :lol:
Zippy drives a Transit! Image
Transit-Tricky
TYRE PRESSURES
Postby woody » Mon Feb 27, 2006 10:15 pm
TRICKY YOU SAY YOU PUT 50psi front 53psi rear on 8plys ARE THESE CROSSPLY OR RADIALS I THINK MINE MUST BE UNDER INFLATED ON MY MINIBUS AS I ONLY HAVE 40psi FRONT AND 45psi REARS I DON'T KNOW IF THIS IS RIGHT . I HAVE RADIALS ON MINE.
woody
Postby transitgeoff » Mon Feb 27, 2006 10:17 pm
Woody, get 50psi all round in yours that,ll be ideal Geoff :D
transitgeoff
Postby Valsheda » Mon Feb 27, 2006 10:19 pm
It should tell you what the max psi is on the side of the tyre , if yer not fully loaded then dont put the max in :)
Valsheda
Top Tourneo Owner
Postby woody » Mon Feb 27, 2006 11:48 pm
THANKS GEOFF THEY HAVE ALWAYS SEEMED LOW.
woody
tyre pressures
Postby trannyvam » Sun Mar 05, 2006 10:27 am
hi aztran, you can check what your tyre pressures should be on a web site called "thetyrepressuremonitor.com"at tha bottom of thier home page do a search ,hope this helps mine is a 80 swb it recons 50 front and between 38 and 45 rears depending on how heavy and how fast you want to go
NOW GET A BIGGER HAMMER!
trannyvam
Postby oldsaltoz » Sun Mar 05, 2006 10:21 pm
Have a look next to the foot well/step on the drivers side, I have a sticker that advises 41 PSI front and 70 PSI rear for full load and 8 ply tyres.
1998 Mk 5 Smiley, 2.5 diesel turbo, LWB Mid roof. Mobile tool box and storage.
oldsaltoz
