SMILEY 2.5 Di WON'T START FIRST THING
Postby john leeman » Thu Mar 02, 2006 6:56 pm
CHANGED EVERY THING, DODJEY INJECTOR BETTER BATTERY, FUEL FILTER NEW AIR FILTER, STARTER SPINS OVER FAST ENOUGH , BUT JUST GETS SLOWER AND SLOWER. YET TOW IT OFF AND THE ENGINE ONLY TURNS ONLY 1/2 A REVOLUTION AND SHE'S AWAY. THEN PURFECT AFTER THAT, RULING OUT FUEL SYSTEM TROUBLE ? , I COULD BE WRONG. THIS ONE HAS GOT ME BAFFELED, HELP !.
35 years of driving,repairing,sleeping in transit's lovin every minute.
john leeman
Postby Luke » Thu Mar 02, 2006 6:59 pm
take it youve checked the wires to the starter and the earth lead john :?
Postby MrMPuk » Thu Mar 02, 2006 7:24 pm
If the van will start as soon as you use a jump pack or something then you know it's bad connections.
Postby crazyscoot » Thu Mar 02, 2006 11:07 pm
wot he above two gents said :wink:
Negative reality inversion
crazyscoot
Postby bortaf » Thu Mar 02, 2006 11:50 pm
check the voltage at the stop solenoid when the engine is cranking.
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby transitgeoff » Fri Mar 03, 2006 8:07 pm
fuel pump :(
transitgeoff
alternator
Postby paul stokes » Thu Mar 23, 2006 8:44 pm
I found the same problem was cured by chopping the alternator electrical block connector (back of alternator) off of the wire and putting on new separate spade connectors, did the trick for me . use loads of tape to prevent arcing
paul stokes
sorted, won't start.
Postby john leeman » Thu Mar 23, 2006 9:26 pm
WOULD YOU BELIEVE IT, BATTERY SPLIT ALLOWING ACID OUT OF 1 CELL EVENTUALLY. CLEAN & PAINT BATTERY SHELF, NEW 096 BATTERY AND BOB'S YOUR UNCLE. WHO WOULD HAVE THOUGHT OF THAT. I SHOULD HAVE.
john leeman
