gearbox drain/fill plug........again
Postby piperdog » Thu Mar 02, 2006 8:07 pm
i know its been asked before ,ive located the gear box fill plug (couldnt they of made it any smaller )...but where is the drain plug :?
2001 rear drive :?
piperdog
Postby MrMPuk » Thu Mar 02, 2006 8:09 pm
Not sure there is one! With it being a maintenance free box it doesn't require oil changes, but if you really feel the need you can suck the oil out the filling hole!
Postby Nighthawk » Thu Mar 02, 2006 10:22 pm
The drain bung on the MT75 is fitted to the rear casing of the gear box on the drivers side of the box.
With the box fitted, it's obscured by the mounting.
your looking for a flat bung with an 8mm allen key fitting.
Nighthawk
