FredTransit wrote:I am not used to seeing the third measurement. I have only ever been used to 185x14s
Luke wrote:yeah usually 195 R14C i think its about an 80% profile so same as 195/80R14
Luke wrote:wow i'm impressed puts my 'ms paint' drawings to shame
Luke wrote:if i was drilling them i'd probly go for 2mm towards the origanal hole and 6mm from the end and if you didnt go for welding the origanal holes up you could plug them with a machined dowel (that would also protrude into the halfshaft) to give it more strength
and remember the half shaft is on top of that which carries more of the rotational stresses
Luke wrote:got me thinking thistheirs actually no drive on that part its purely there to hold the wheel on the halfshaft takes all the drive
how about a solid disk ring on the back of the hub which the studs go through
not that im aware ofHaxman wrote: Someone mentioned to me if i take both half shafts out at the same time I might not get them "lined up" when refitting them, any trueth in this or will they both go back in fine?
i think you could machine a flat face onto the existing hub and mate a ring to that - but like you say its gonna push the cost upHaxman wrote:A solid disk ring would certainly be the best solution but wouldnt that require a whole new hub to be machined!!
and would it fowl the brake shoesLuke wrote:i think you could machine a flat face onto the existing hub and mate a ring to that - but like you say its gonna push the cost upHaxman wrote:A solid disk ring would certainly be the best solution but wouldnt that require a whole new hub to be machined!!and is it really necassary
