5 speed / od gearbox in mk1
Postby irover » Fri Sep 05, 2008 12:53 am
Hello
What gearbox can i use to replace the 4speed in a mk1 transit 2 litre? Can i use a different gearbox from taunus or sierra or someting. Or should i use an OD box? Also changing the rear axle ration would be fine too if i can get something that fits. Ford Zephyr maybe?
irover
Re: 5 speed / od gearbox in mk1
Postby manandvan » Fri Sep 05, 2008 11:18 am
hello i would go for the overdrive box myself its the easiest option, you will need to drill a couple of holes for the cross member and remove the overhead gearbox carrier, also add a prop centre bearing carrier, but all much easier than messing about with back axles and butchering your gearstick hole. 8)
manandvan
Postby FredTransit » Fri Sep 05, 2008 11:22 am
I think the overdirve is the only option, if it's a V4.
FredTransit
Mk2 Trannyist
Postby Squirrel » Fri Sep 05, 2008 2:26 pm
I've had Zephyr-6 crown wheel and pinion fitted to orginal Mk1 diff to accomodate Ford 3.0 liter V6 motor with Cressida 5 speed gear box.
[b]TRANNY'S FOR AFRICA!!
Wife?Tranny?wife?Tranny?...the choice is obvious![/
b]
Squirrel
Postby bron y aur » Fri Sep 05, 2008 8:27 pm
5 speed type 9, sorted
i started with nothing, still have most of it left
bron y aur
Postby FredTransit » Fri Sep 05, 2008 8:51 pm
well apart from the fact the type9 is pants.
FredTransit
Mk2 Trannyist
Postby transitgeoff » Fri Sep 05, 2008 8:58 pm
type 9 is ok if its in good shape, also changing the diff ratio is the way forward if your looking for a higher speed at lower revs, much more effective than a box change :D
transitgeoff
Postby Luke » Fri Sep 05, 2008 10:19 pm
what bellhousing mates a V4 to a type 9 :?:
Postby bron y aur » Mon Sep 08, 2008 3:20 pm
A 4 speed type E bellhousing on a type 9 with a long input shaft, i hope lol.
bron y aur
Postby madmark » Mon Sep 08, 2008 7:02 pm
dont forget the type9 has a bit that comes out of the gearbox when selecting reverse ,the type 9 bellhouseing has this bilt into it! :wink:
Postby Luke » Mon Sep 08, 2008 7:41 pm
is the bolt pitch the same i awlays thought they were different :?
Postby madmark » Mon Sep 08, 2008 7:44 pm
from memory i had a conversion made to rover , it had to have a hole cut out in the bellhouseing so to select reverse !
:wink:
Postby Luke » Mon Sep 08, 2008 7:49 pm
i once lent a bellhousing to a mate so he could do this conversion and he told me the bolts were different - mabe thats what he meant :D
do you mean you had a type 9 on a rover v8 :shock: :?
Postby madmark » Mon Sep 08, 2008 7:53 pm
:lol: :lol: yes for a short wile , the bellhouseing was made from a coulpe of difrent ones and joined!
in the end i went auto! :lol:
Postby FredTransit » Tue Sep 09, 2008 10:21 am
Joined? Wasn't it cast iron? How/where was it joined?
FredTransit
Mk2 Trannyist
Return to Mk 1 & 2
