Bleeding transit connect 1.8 tddi 75ps
Postby Drago » Sat Sep 20, 2008 6:31 pm
Ok major dilemma here.
Have just changed the fuel filter on my 2005 75ps tddi transit connect.
Unfortuantely i didnt read up on having to fill the fuel filter with diesel before you try starting the engine.
So obviously i have lots of air in the pipes.
I have tried cracking the injectors and cranking the engine over, it seems a small bit of air is coming out but to me it doesnt seem like there is much fuel being pumped to the injectors if any at all.
What is the next step as i really need the van for monday :(
Cheers in advance :)
Drago
Re: Bleeding transit connect 1.8 tddi 75ps
Postby transitgeoff » Sat Sep 20, 2008 6:35 pm
welcome :)
transitgeoff
Postby Drago » Sat Sep 20, 2008 6:53 pm
Cheers mate. :)
Drago
Postby motorwise » Sat Sep 20, 2008 8:16 pm
keep cranking it - it will start eventually
http://www.motorwise.net
motorwise
Postby transitgeoff » Sat Sep 20, 2008 8:18 pm
or i have starters, new, used or recon :wink:
transitgeoff
Postby motorwise » Sat Sep 20, 2008 8:19 pm
transitgeoff wrote:or i have starters, new, used or recon :wink:
:D :wink:
motorwise
Postby MinorMatt » Sat Sep 20, 2008 8:28 pm
Just a thought... have you taken the filter off again and filled it with diesel??
Postby Drago » Sat Sep 20, 2008 8:31 pm
The filter has a fair amount of diesel in it but its not full.
Should i fill it right up?
Drago
Postby MinorMatt » Sat Sep 20, 2008 10:09 pm
I would ;) Or top it up with injector cleaner
Save your battery a bit!
Postby Drago » Sun Sep 21, 2008 9:02 am
Ok will give that a try today. Managed to pretty much flatten the battery yesterday with all the cranking.
Would one of these diesel priming bulb tools do the job?
Drago
Postby icallediton » Sun Sep 21, 2008 10:06 am
try and tow start it its better than burning out the starter motor
icallediton
Postby transitgeoff » Sun Sep 21, 2008 10:51 am
the moral of this thread is ...dont touch what you know F**k all about ! pay someone who does, its cheeper in the long run :wink:
transitgeoff
