Brake servo replacement
Postby madmark » Tue Apr 05, 2005 4:04 am
for some reason the drum brakes has a smaller servo see pick
Postby madmark » Tue Apr 05, 2005 4:16 am
Postby claypole » Tue Apr 05, 2005 10:57 am
You guys are nuts - I've clearly come to the right place :lol:
Mark, thanks for the pic, diff to be certain from a photo but I reckon that's exactly my set up. Can you just unbolt it and post straight away please :lol:
I presume that disc brake models have a larger servo and so Mk2/3 not really an option unless I'm planning on a disc upgrade (not in the least bit likely :lol:
Also, I presume later models had diagonal lnked systems (ie front R rear L together) whereas mine has two outlets for front, both off secondary chamber and just 1 outlet for rears off primary chamber so I'm guessing parts are not really interchangable unless changing every single braking component. I could be wrong.......
Now have m/c repair kit. This includes vacuum seal between m/c and servo which was completely absent from vehicle on dismantling. This could go someway to expalining lack of effective servo :lol:
Now rebuilding m/c and will fit to servo with new seal and pray. Not optimistic but I don't know how else to test servo.
Wish me luck or send further advice (or complete mk1 servo andm/c assemblys Mark) :D .
claypole
Postby madmark » Tue Apr 05, 2005 1:30 pm
i would like to go discs in the future but not yet ,my brankes were great when i first got it now they pull alover the place! :(
Postby claypole » Tue Apr 05, 2005 7:32 pm
Having drained best part of a gallon (!) of liquid from servo m/c now rebuilt and attached to cleaned up servo and looking more like it should. But will it work like it should? Sadly Mrs Claypole and Claypoles junior insist we continue with our pre-booked holiday early tomorrow so I've got to wait another week to find out :cry:
Camping weekend planned for end of April so pressure will be on after holiday - haven't even started on interior yet :lol:
Wife thinks it might be easier to patch the tent - but where's the fun in that?
Will post progress here or Mk1 board in a while.
claypole
Postby madmark » Tue Apr 05, 2005 7:46 pm
you cant go away without dooing the servo it will be on your mind all the time!!! :lol: :lol: :lol: :lol:
Postby FredTransit » Tue Apr 05, 2005 8:37 pm
madmark wrote:you cant go away without dooing the servo it will be on your mind all the time!!! :lol: :lol: :lol: :lol:
Too right, actually for a minute there I thought that you were going to say that you were taking the camper!! :lol: BTW Mark, was that pic taken just before you had you dinner off the engine? :wink:
FredTransit
Mk2 Trannyist
Promised update on Mk1 Camper
Postby claypole » Wed Apr 20, 2005 11:45 pm
Yesssss! Managed to get through the holiday without catching an early flight back. And after all the suspense of waiting, finally put the servo and master cylinder back on with nothing more than a faint glimmer of hope that we might be in business and what do you know - success. Couple more wheel cylinders later (broke the bleed nipples) and the brakes are now in full working order and as good as 1974 drum brakes on heavy motorhome ever were. Patched exhaust didn't remain patched very well but local exhaust guys managed to provide some pipe and a silencer that were vaguely similar and made to fit. Best bit is she sailed through MOT :shock: and received a brand new tax disc for her pains today (wish I'd found a pre 73 now). Camping booked for week on Friday so better get busy on the inside. Actually, already have - fridge check, oven/grill hot plates check, Heater (such luxury) check, water - bugger. pump ok but have leak on first intake which means the whole thing is down but heh we'll take some bottles. Spit and polish, lots of elbow grease and should be ready to search out the sleeping bags. Wife is slightly suspect that 200 miles each way to the New Forest is maybe pushing it for the maiden voyage but I've got every faith - and at least we'll be comfy while we're waiting rescue :D
Would love to post pics but can't seem to work it. Do they need to be on a server and is it not possible just to post pics from hard drive?
claypole
Postby claypole » Wed Apr 20, 2005 11:52 pm
Dohh :? Just found the "post image" in FAQ so I guess that's a no for me.
claypole
Postby madmark » Thu Apr 21, 2005 2:47 am
mate if you have problems with picks post them to fred she will put them on for you! :D
Postby FredTransit » Thu Apr 21, 2005 8:17 am
madmark wrote:mate if you have problems with picks post them to fred she will put them on for you! :D
.........ya beat me to it! Feel free claypole! :D
FredTransit
Mk2 Trannyist
Postby claypole » Thu Apr 21, 2005 10:54 am
Thanks both. Have now seen excellent advice elsewhere on site for using photobucket so hopefully will sort tonight, failing which I'll come back to you Fred thankyou. :)
claypole
Postby claypole » Thu Apr 21, 2005 4:57 pm
WOW :shock: It's that easy. Thanks a bunch.
This is just a pic from when I first found / viewed my baby. I'll try and post more on the appropriate board soon.
Fred, hope you don't mind, I added a sub-album to the account. I haven't looked yet to see if you have any kind of size limit but I can delete it as soon as my account conf comes through if you like.
Bye for now (back to work after long tea break!! :)
claypole
Postby FredTransit » Thu Apr 21, 2005 7:06 pm
No I don't mond about a sub album, it hadn't occurred to me that there is a limit. But then again, I guess Luke hadn't realised what a monster he had made either! :D
FredTransit
Mk2 Trannyist
cron
