need higher gearing!
Postby nitroman » Fri Mar 10, 2006 2:18 pm
i run a 125 ps swb thats chipped and has a nitros system fitted (not joking !) i now wish to alter the gearing as i run out of revs at 115 mph and i need a taller 1st gear to aid tracton off the line.this aint a wind up and by the way it all works really well and seems reilable for the 2 years its been modded!!
nitroman
Postby stevew » Fri Mar 10, 2006 2:31 pm
FWD or RWD?
What mk?
Steve
stevew
Postby 100ps_drw_hicube » Fri Mar 10, 2006 2:33 pm
mk6 fwd :D
100ps_drw_hicube
Transit Abuser!!
Postby stevew » Fri Mar 10, 2006 2:37 pm
Tricky then!
Steve
stevew
Postby 100ps_drw_hicube » Fri Mar 10, 2006 2:42 pm
best bet would be to pm nighthawk he might know :?
or a gearbox place could be the other option :?
100ps_drw_hicube
Transit Abuser!!
will try nighthawk chers ta!
Postby nitroman » Fri Mar 10, 2006 2:44 pm
will try nighthawk thanks!
nitroman
Postby Nighthawk » Fri Mar 10, 2006 6:18 pm
Pm returned 8)
Nighthawk
Postby 100ps_drw_hicube » Fri Mar 10, 2006 6:25 pm
Nighthawk wrote:Pm returned 8)
so is there anything that can be done to get his transit to go faster ? :D
100ps_drw_hicube
Transit Abuser!!
Postby madmark » Fri Mar 10, 2006 7:35 pm
:shock: wow 115mph thats double what mine does! :lol: :lol:
need higher
Postby Neil » Fri Mar 10, 2006 8:09 pm
madmark wrote::shock: wow 115mph thats double what mine does! :lol: :lol:
he still won t get there twice as fast
Neil v6
Neil
cheers for your advice chaps
Postby nitroman » Sat Mar 11, 2006 12:28 am
thanx for your advice and to those who pointed out my pics to big im trying to make it smaller ta...
nitroman
Postby Milemuncher » Sat Mar 11, 2006 10:37 am
Sounds a great van, give those BMW drivers a lesson on the motorway !
Have you modified the suspension at all, as I'd be interested to know how you keep it on the road. Over about 75 my van is as stable as a Reliant.
Milemuncher
Postby nitroman » Sat Mar 11, 2006 10:51 am
no the suspension is standard, it seems really stable but even the standard 125ps version will do 112+ on a good day so i guess its designed to go that fast eh!! and yup theres nowt better than blowin off all but the most powewrful cars!!
nitroman
