Will changing my van into a camper make it more valuable?
Postby mikke » Fri Oct 03, 2008 8:21 pm
I was thinking of converting the van into a camper
as it is a lwb high top.
what do you guys think?
If it's not broke, "Don't try to fix it!"
mikke
Re: Will changing my van into a camper make it more valuable?
Postby MrMPuk » Fri Oct 03, 2008 9:54 pm
Depends how good the conversion is.
Postby mikke » Fri Oct 03, 2008 10:49 pm
something like this
mikke
Postby MrMPuk » Fri Oct 03, 2008 11:03 pm
Well if it's to that standard them I'm sure it will.
Postby Luke » Sat Oct 04, 2008 9:21 am
generally they do and like mike said depending on how good the conversion is :D - the only ones that devalue the van are mk1 and mk2's -it's the cutting in windows that does it :(
Postby chipv8 » Sat Oct 04, 2008 9:47 am
A good quality (Certifiable) job should definately add value. Fit and finish a paramount to getting the cost of converting back when selling on. You also need to consider layout, and design everything for optimum use of space and ergonomics.
An example is the bed shown in your picture:- you couldn't fit a bed widthways in a transit far too narrow a space. it would be fine for kids or perhaps you would put up with it but a paying customer wouldn't (they come in all shapes and sizes).
The van you use will also need to be really tidy, and if your fitting out with gas that needs a safety certificate
Google the self build motor caravaners forum very helpfull, although you can't post without paying up (swindlers). Also Halfords are selling an Haynes manual about the very subject which I myself have brought and it's very interesting, and full of advise tips and contacts etc.
Back In the Black Country!!
chipv8
Postby trigger » Sat Oct 04, 2008 7:03 pm
That's a very good standard, makes mine look very basic.
Mk5 Transit the daddy
trigger
Postby trigger » Sat Oct 04, 2008 7:06 pm
As for windows you would prolly be better off starting with a large mini bus that has windows already in it.
trigger
Postby foggy08 » Sun Oct 19, 2008 2:30 am
i think you will find insurance will be cheaper as well ...this should make desirability better..therefore worth more
ouch ..suarez bit my finger
foggy08
Return to Transit Talk
