Fault is driving us crazy - Please Help
Postby vmax » Wed Mar 08, 2006 4:34 pm
Hi all,
Anyone shed any light please on the following. We have an 02 reg Transit 350 tipper that developed a rattle on tickover. We stripped and replaced the dual mass flywheel and clutch. Upon reassembly it will start, then immediateley cut out again. Checked with fault code reader, which suggested the Crank Position Sensor. Replaced this, still the same. Stripped out the flywheel again! and confirmed that it is identical to the old unit. Rebuilt, and as before will start straight away, then cut out immediately. Immobilsor checks out fine. When it starts it runs for only a second or two. ????????????????????
vmax
Postby transitgeoff » Wed Mar 08, 2006 8:09 pm
have you the correct plug on the flywheel sensor as from experience i know that the speed sensor plug is the same and can fit the flywheel sensor, it is at the propshaft end of the gearbox but how the wiring is routed they can interchange when the gearbox has been removed.
transitgeoff
Postby cdl123 » Wed Mar 08, 2006 8:59 pm
i would also check you have the wiring on the right connectors it does sound like you have mixed the up
cdl123
Postby Nighthawk » Wed Mar 08, 2006 9:05 pm
i'd also suggest that the CKP and the VSS have had their plugs crossed over, it'll be easy to spot if they have as the speedo will record both speed and miles while cranking or for the 2 to 3 seconds it takes the PCM to spot that it can't syncronise the crank position with the fuel pumps cam position sensor.
Nighthawk
Postby trannytech » Wed Mar 08, 2006 10:09 pm
had the same fault once it was a really loose timimg chain changed the tensioner and guides was ok after that . had pump timing codes &ckp sensor codes
trannytech
Postby vmax » Thu Mar 09, 2006 10:42 am
Gentlemen, many many thanks, plugs reversed as described, all is now well. Excellent responses, very grateful.
vmax
Postby Nighthawk » Thu Mar 09, 2006 7:51 pm
8)
Nighthawk
Postby chrisuk » Sat Mar 11, 2006 12:27 am
Interesting reading my X reg 90ps 2,4 rear wheel drive occasionally cuts out after I've driven it, feels like as if its like the old petrol cars did when the fuel boiled in the carb, starts up then cuts out as your about to pull away, red led light shows no odd reaction, its ony done it about 3 times since I've been in Spain, I guess I could also be trying to pull away at times at low revs, like I say it doesnt do it often and it hasnt a regular pattern, posibly Im been parinoid after the £1300 fuel injecotr pump replacement.. :roll:
chrisuk
Postby FredTransit » Sat Mar 11, 2006 6:13 pm
Yay! Chris, how's it going? Settling in?
FredTransit
Mk2 Trannyist
Postby chrisuk » Sun Mar 12, 2006 8:43 am
FredTransit wrote:Yay! Chris, how's it going? Settling in?
Going well, settling in no, dont tlike this village, Cuavas de San Marcos its called, but its only temp till I find somewhere closer to the coast where all the brits live :roll:
chrisuk
Users browsing this forum: Trev_
