Axle Rebuild
Axle Rebuild
Postby hornhead » Mon Oct 20, 2008 3:52 pm
Anyone had success with H axle recon diff to cure whine? Any recomended workshops, am thinking of MTS. Going to change ratio..
could 2.0 pinto pull a 3.9 diff or am I just giving myself one more reason why I need a cologne for Christmas!
Haynes :( 'go by the Forum' :)
hornhead
Re: Axle Rebuild
Postby BigNeil » Mon Oct 20, 2008 4:24 pm
i know you know where you are but we do not any specific areas for a workshop ?
invernesshire perhaps ?
BigNeil
Re: Axle Rebuild
Postby hornhead » Mon Oct 20, 2008 6:21 pm
... duh... brain...I'd go a long way for a decent axle but realistically london,southeast up to midlands.
if you can bring one from inverness to Billing the beers on me :D
hornhead
Re: Axle Rebuild
Postby BigNeil » Mon Oct 20, 2008 6:37 pm
i do not have one but no one knows where you are !!!
so could have been from Australia for all we know
BigNeil
Re: Axle Rebuild
Postby farsalvage » Thu Oct 23, 2008 10:29 am
i got a rebuild kit from http://www.abbeytransmission.co.uk/
i gather they also do an exchange axle, just tubes and diff.
as i recall the axle re-build kit, all bearings, seals, spacer and pinion and crown wheel was £325. with p and p and vat
axle was about £500.. wish i'd gone with axle, would have been easier and cheaper in long run.
i think they do a fitting service as well..
either way, very helpfull and know the game inside out..
farsalvage
Re: Axle Rebuild
Postby hornhead » Thu Oct 23, 2008 7:15 pm
Thanks for link,will call them tomorrow.
was your axle the salisbury or unboltable H type Timken diff?
did you rebuild it diy?
hornhead
Re: Axle Rebuild
Postby farsalvage » Thu Oct 23, 2008 7:40 pm
its a twin wheel one, 1993.. the diff cover comes off, so you unbolt the diff and pull it out from the rear.. i put all the bits in, adjusted as best i could then took it upto kevin at the gearbox centre, in caister near great yarmouth, he set it all up properly..
i had to replace mine as it had been noisy for years, then it decided to break a few teeth off...
it runs nice and quiet now.. still i wish i'd bought the tube axle as you just swap it over, fit your brakes and half shafts job done.. much easier than fitting a diff.. job for the experts really, getting the crushable washer and backlash etc right is a nightmare..
farsalvage
Re: Axle Rebuild
Postby hornhead » Sun Oct 26, 2008 11:33 am
Thanks for pics, pinion looks like you dropped a supercharged v8 in it!
Advice taken,no diy,need to stay on road
hornhead
Re: Axle Rebuild
Postby farsalvage » Sun Oct 26, 2008 1:56 pm
if only!!! i think it was because all the bearings were shagged out..
the normal transit drone just got worse and worse.. i was in the process of thinking i wish it would either get worse or go away.. about ten mins later bang it went..
still drove it back to workshop about 6 miles.. the noise was amazing!! if you want to get looked at, drive around with a broken diff..
farsalvage
