mk3 steering box on a mk1/2
Postby Luke » Thu Oct 16, 2008 10:14 pm
anyone here got a mk3 box on their mk1/2 :?:
either a heavy duty one or a pas one :?: i believe the mounts are differnt and the coulmn i know is, as it has the joint in :)
any help on how it was fitted would be appreciated - and pics would be good :D
ive got a heavy duty mk3 burhman box that im considering fitting to my mk1 :D
Re: mk3 steering box on a mk1/2
Postby cyberchild » Fri Oct 17, 2008 5:51 am
i take out my mk3 box from a pickup -86 one month ago. it fits the mk2. I will try to open it one day to see if i can use the mk2 steering "pole" up to the steering wheel. More powerful?? the mk3.. you say ??? interesting??
I am looking for some heavy duty steering box, too.... as my mk2 box has run 220.000km.
cyberchild
Postby cyberchild » Fri Oct 17, 2008 5:53 am
Oh i almost forgot... the mk3 pittman arm is somewhat different. it will fit the mk2 if you work a little 1cm with a grinder.... it seems more HD.
cyberchild
Postby transitgeoff » Fri Oct 17, 2008 8:01 am
go pas luke, you know it makes sence :D you need the mounting plate from a mk3 make sure it has 5 mounting holes if i remember as the pas mounts are wider appart, i have it on my mk1 :D
transitgeoff
Postby Luke » Sun Oct 26, 2008 2:53 pm
transitgeoff wrote:go pas luke, you know it makes sence :D you need the mounting plate from a mk3 make sure it has 5 mounting holes if i remember as the pas mounts are wider appart, i have it on my mk1 :D
i'd like to mabe long term go for pas - so are you saying the pas mount is different to the non pas mount :?:
and is the burhman box any better than the standard one :?:
found this on frederik's progress thread mk2 with mk3 pas
Postby transitgeoff » Sun Oct 26, 2008 3:38 pm
only the later mk3 has the bigger mount that will hold the pas box :wink: i think all the mk3 with mt75 will be ok :)
transitgeoff
Postby Luke » Sun Nov 09, 2008 8:04 pm
i think what i'll do is fit the mk3 h/d box and mount for now and see how it is :D that way if i want to change to pas ive got the right mount to bolt it to later :idea:
the only thing that puts me off the pas box is the reliability :?
Postby cyberchild » Mon Nov 10, 2008 7:29 pm
for some month ago i take off my mk2 box and steering wheel, all together and i took some measures. I found out that 3 holes in the torpedo wall has to be drilled, and the steering box is fitting... one problem with my mk2... its not large.. but the pittmans arm from mk3 to mk2 is different, and you will see that if you got them both... the steering rod is almost touching some metal, and you will have to grind some away... not a big issue... But the bigger issue was the mk3 steering and switch and all that stuff that goes with in the dasjhboard. Some holes has to be drilled, but thats it.... I have not buildt the mk3 steering box on my mk2 afterall since i will use a mk2 heavy duty aftermarked one. but it was cool to see it fit..
My question is, what oil is there on the steering box.... since my mk3 box was leaking, my mk2 box is dry... so i wonder???
cyberchild
Return to Mk 1 & 2
