Front Leaf Spring Bushes.
Postby cartooner » Fri Oct 24, 2008 12:48 pm
Hi,
I need new bushes for my front leaf springs on the Mk1. I already have the 8 rubbers for the rear side, but now I need new ones for the frontside. These are the pressed-in ones with the metal inner. They are 67mm wide, 46mm thick with a 18mm center hole. Motomobil does not deliver these anymore. Can anybody overhere source them for me.
Perhaps an adress in the UK somewhere, please.
Thx.
cartooner
Re: Front Leaf Spring Bushes.
Postby transitexpress » Sat Oct 25, 2008 7:41 pm
Try your local motor spring manufacturer / repairer. :)
Old transits need never die just keep mending em!
transitexpress
Postby Sundowner » Sun Oct 26, 2008 10:54 am
not a hard thing to get
most replacment bushes are 2 peice
Yeah i know its big green and rusty so move your Porsche before i bash it with 460 cubes of fords finest cast iron
Sundowner
Postby cartooner » Mon Oct 27, 2008 8:08 pm
Still no luck. Nowhere on the internet. Only advice I got sofar is to let someone
fabricate them from solid nylon. So if anybody knows where to buy them, please tell. It's easy to find the rear ones but not the front bushes.. Motomobil has some in stock, but not the ones I need. 67mm wide/ 46mm Diam./ 18mm inside diam.
cartooner
Postby transitexpress » Tue Oct 28, 2008 10:16 am
Try Midland Motor Springs at Holme Pierrepont, Nottingham on:
0115 981 7759. :)
transitexpress
Postby cartooner » Tue Oct 28, 2008 5:51 pm
Just asked them through e-mail. Thx!
cartooner
Postby Southerner » Tue Oct 28, 2008 11:53 pm
There's a set on UK e-bay right now, daylight robbery mind:
http://cgi.ebay.co.uk/TRANSIT-MK1-MK2-L ... 286.c0.m14
Southerner
Postby cartooner » Wed Oct 29, 2008 10:03 am
Wow. Thx man. These are the ones. Hands of everybody,(please). I took a close
look and my name is written on these. What a coincedence!
cartooner
Postby Neil » Wed Oct 29, 2008 1:04 pm
same seller got dozens of em :lol:
Neil v6
Neil
Postby cartooner » Wed Oct 29, 2008 1:10 pm
But I've got none :(
cartooner
Postby chrisvmax » Wed Oct 29, 2008 3:22 pm
£25 :shock: wow. I just bought a pair of these for my MGB... £8 per pair. Pity they're too small for the transit
chrisvmax
Postby Sundowner » Thu Oct 30, 2008 10:25 am
Sundowner
Postby travlinman » Thu Oct 30, 2008 11:56 am
pity they not the right ones
travlinman
Forum fool
Postby cartooner » Thu Oct 30, 2008 1:50 pm
travlinman wrote:pity they not the right ones
I think they are the right ones though. The inside diam. is 22,2 mm. But You have to insert the cross tube which is 22,2 outer and 18mm inside diam. So indeed I think these would fit too. They are 113 Aust.Doll. and in cluding tax and shipment that will be quit expensive. About 46 pounds excl. shipment and taxes. But they are
poly bushes. 8)
cartooner
Postby Sundowner » Fri Oct 31, 2008 8:30 am
they are the correct ones
Theres another place called Nolathane that maked them
Sundowner
Return to Mk 1 & 2
