mrg wrote:HI its mr torneo engine change.
in end put mondo tdci 2.2L 155ps in. just ran it up the uther day sounds pretty good so far. all i have to do now is sort the boost acuator out, ive welded a pipe in to the boost side to fit a boost gauge so i can adjust the acuator, if dose eney body know wate the boost shud be ??
martynx wrote:Good on ya Man, thats one i would i have been wanting to do. PLEASE let me map it afterwards if it goes ok..
winterheating wrote:martynx wrote:Good on ya Man, thats one i would i have been wanting to do. PLEASE let me map it afterwards if it goes ok..
sertainly will, i'll do a few other mods first. do you know of anywher i can get the van on a roller, the only place i know can't fit my van in the door.
mrg wrote:Hi, all modeo loom was removed and old tourneo loom fitted, egr and cooler removed, tourneo egr and cooler fitted, drive shaft bearing support changed over, manifold, alternator, ac pump, frunt engine mount, not to shur wether good ider or not but changed rail senser over to. flywheel clutch pressur plate all same, all bolted together fine, it started up fine, but with no boost controler at moment,
the turbo is the 2.2L tdci one so i have taken the electronic acuator off witch operats the V V control and am about to fit and ajust the vacum control unit from origenal set up to operate turbo. im sure it may ned a bit of mapping though. i havent driven it yet but i set the boost control half way and let my dear wife try it (as it is for her) dont know how good it was but it took me an hour to get her out??. that boost quoted sounds a bit high dont know wether my pcu will allow that. Mike
ryzman wrote:hi is the van semi high?? cos i know of a guy who will do it! then martin coud meet up and adjust my van a bit more to
Users browsing this forum: Chrispduck, gt_addict
