dashboard
dashboard
Postby custom » Fri Mar 17, 2006 11:10 am
hi im looking at a l reg minibus but its got the horrible dash wat i want to know is will a 2000 dash fit in it? if so how easy is it to do cheers
custom
Postby MrMPuk » Fri Mar 17, 2006 11:17 am
I wouldn't have thought so as the 2000 van has a completly different dash.
Postby madvanman » Fri Mar 17, 2006 11:23 am
you can get any dash to fit if you dont mind lots of work :)
it will be a lot of work to get a 2000 onwards dash to fit into a pre 2000 transit,
you would be better off going for a 1995 - 1999 dash as its mostly a bolt in job, although i think you will need to change the heater box as well
madvanman
Customised!!
Postby custom » Fri Mar 17, 2006 12:04 pm
thanks for that ill double check on the year cheers
custom
Postby Luke » Fri Mar 17, 2006 1:49 pm
do you mean the later 95-2000 dash the one after yours or the 2000 onwards one? :D
Postby custom » Fri Mar 17, 2006 3:17 pm
it was a 2003 and it wont fit im after a 95-99 one but am unsure how to fit it any one help me out?
how 2 maybe or give me a hand?
custom
Postby MrTransit » Sat Mar 25, 2006 9:08 pm
The 95-99 dash will fit, but theres a lot of work to do.
The heater box will need to be changed to the 95-99 type and there will need to be some cutting to the bulkhead as the heater pipes don't line up and the air inlet on the bulkhead also needs some cutting. the mounting bolts (4 of them) also don't line up!
The 2 bolts on either side of the dash by the door seal do line up and the 3 mountings along the dash top line up also but the mountings on your van will need to be drilled to accept screws as the earlier fixings were push fit connections.
You will also need to to fit the A-post trim to match the new dash, the mountings on your van are small plastic bungs in which the original screws screw into. when you remove these the holes (3 along the A-post) need to be widened with a file or a drill to fit the 95-99 plastic bungs, as they are wider.
You'll need to do some jiggery pokery with the wiring too, i'd prefer to modify the existing loom rather than swop to the later type, although if you have a complete loom from the later van it can be done but will add a lot more work. things you will need to change are the connections to the gauges and the heater blower motor and switch i think, you also need to provide a connection for the clock and extend the wiring for some switches such as the fog light switch. and radio connections too possibly.
you will also need to get a black stick on sunvisor as sold by any motor accessory shop. this needs to be stuck to the bottom 3 inches of your windscreen on the inside as the new dash is higher than the base of the screen. 95-99 windscreens have a standard blackened section here, if your windscreen has recently been replaced then this might already be there.
I think the gearlever might need to be changed too as the heater box protrudes more in the 95-99 vans
get urself a cheap set of later doors too and fit them if you want matching door cards.
you will then need to buy a cap for your head because you will have most if not all of your hair pulled out in frustration by this stage!
I think that covers most of it, best of luck!
My Transit...1.5 tonnes of pure fun!
MrTransit
Postby custom » Sun Mar 26, 2006 5:13 pm
thanks for all the help but ive bought a nreg transit exectuive thats a mk 4 i pick it up in 2 weeks
custom
Postby Luke » Sun Mar 26, 2006 6:07 pm
custom wrote:thanks for all the help but ive bought a nreg transit exectuive thats a mk 5 i pick it up in 2 weeks
:wink: :lol:
