24v cosworth transplant
Postby Luke » Fri Mar 17, 2006 9:39 pm
yes you will need either a transit adapterplate or a mt75 hybrid with some sort of linkage made up to move the stick further forward!!
or go auto!!!
:D
Postby OxtonyxO » Sun Mar 19, 2006 11:41 am
think auto will be the way till i can find an adaptor plate to copy :(
OxtonyxO
Postby Luke » Sun Mar 19, 2006 9:26 pm
OxtonyxO wrote:think auto will be the way till i can find an adaptor plate to copy :(
the transit auto uses the same box as the granny scorpio A4LDE - you will need an auto prop or get yours modded and possably a gearstick or mabe you can mod the granada one??? not sure!!! :D
Postby Andrew-v4 » Mon Mar 20, 2006 4:04 pm
The autobox on the 24v has a sports/economy mode where as the
standard 2.9 & transit box doesent. Weather or not it make a difference.
Andrew-v4
Postby maxlee » Thu Mar 23, 2006 2:06 am
OxtonyxO wrote:yeah pmcc on newgate lane thats where my vectra go to be serviced
they where intrested in doing the conversion but wanted over a £1000 for doing it top boss was more so looked at doing it my self
all ready had the engine out once when the cam belt snapped had to replace the cam followers and push rods so hopefully all will go ok
:shock: i would do the same as u then :D good luck with it if u want a 2nd pare of hands and i am free give me a shout
maxlee
Postby OxtonyxO » Thu Mar 23, 2006 7:53 am
looks like i may have a an adaptor plate so the manual is back on
OxtonyxO
Postby OxtonyxO » Thu Mar 23, 2006 2:58 pm
have a look at these it is possible :!: :!:
http://www.focusv8.co.uk/transit1.JPG
http://www.focusv8.co.uk/transit2.JPG
http://www.focusv8.co.uk/transit3.JPG
http://www.focusv8.co.uk/transit4.JPG
also found this on another site :oops:
24v v6 into a transit is a doddle, use the granada engine mounts, use the adapter plate and flywheel from a V6 2.9 transit ( although a v6 capri/granada/sierra flywheel can be used with a spacer), diesel clutch can be used, you have to reshape the bulkhead by the clutch peddle by about an inch ( big hammer works well) from the engine bay side, can't remember if you need a different rad. if you can get the engine mounts from a v6 2.9 transit all the better, if not you can use the granada ones, what you do is cut up either side of the engine mount on the transit and bend it up, then weld sides on to support the bit you have bent up this now gives you an engine mount hole laying flat instead of at 45 degrees, you will find the original granada alloy engine mounts drop straight in the holes now.
http://www.focusv8.co.uk/transit.htm
i can say from doing 2 24v transits that you will have loads of fun, a swb van will do the quater mile in low 16's and a lwb will do it in mid 16's, that means you will keep up with the average RS Turbo!!!!!!!!!
any questions email me at john@focusv8.co.uk
next projects out later this year early next year are a 1000BHP focus hence the focusv8 email address and a dodge viper powered caterham type kit car!!!!!!!
getting closer to doing it now :D
OxtonyxO
Postby stevew » Thu Mar 23, 2006 7:20 pm
I love the way they've used a slightly rusty plain white 1986 van! :P
I bet thats a lot of fun at the lights! :twisted:
Steve
stevew
Postby OxtonyxO » Thu Mar 23, 2006 7:33 pm
yeah real street sleeper wolf in sheeps clothing
OxtonyxO
Postby stevew » Thu Mar 23, 2006 7:35 pm
From http://www.focusv8.co.uk
Q: What sort of power can I expect?
A: Normally asperated V8 300-450 bhp
.....Supercharged V8 400-750+bhp
Q: Which Focus can i use?
A: Any Focus (3/5door hatch, saloon or esate).
.....we believe even a Transit Connect uses the same floor pan!!!!!.
.....Now thats express delivery
Now I'm not really a big fan of the Transit connect. I've got nothing against it other than it should be called the Focus Courier or Focus Connect or something. But....
750bhp Transit Connect anyone? :twisted: :twisted: :twisted:
Steve
stevew
Postby Luke » Sat Mar 25, 2006 12:36 pm
OxtonyxO wrote:if you can get the engine mounts from a v6 2.9 transit all the better, if not you can use the granada ones, what you do is cut up either side of the engine mount on the transit and bend it up, then weld sides on to support the bit you have bent up this now gives you an engine mount hole laying flat instead of at 45 degrees, you will find the original granada alloy engine mounts drop straight in the holes now.
thats handy to know!! :D
Postby OxtonyxO » Sat Mar 25, 2006 12:39 pm
the info on the granny mounts is unconfirmed :(
OxtonyxO
Postby Luke » Sat Mar 25, 2006 8:03 pm
with the mounts i was thinking about making an adapter plate to bolt to the V6 block and either the Di or pinto mounts could bolt or weld to it!
:idea:
Postby OxtonyxO » Sun Mar 26, 2006 6:06 pm
got my granny now a bit late but its here all runs ok revs ok dont smoke well happy :D :D
only problem is a bloody clifford alarm but shold a alright to get out
camera not charged so get some pic when i can
OxtonyxO
Postby OxtonyxO » Sun Apr 02, 2006 7:21 pm
ok started to remove the granny engine today all going as expected apart from some regulators and a few other bits
heres some pics
does any one know what these do
OxtonyxO
