mk2 180degree opening doors
Postby mike c » Fri Dec 12, 2008 10:46 pm
today i went to the builders merchants to get some hardcore for the garage floor, first attempt failed as the fork lift couldnt get the bag in due to the doors only opening 90 degrees
so i came home, drilled out the pins for the door openers and voila! the doors open fully and the bulk bag went in fine... managed to get home too, the rear tyres were scraping a lot and it was very low at the back but ho hum.
i thought id let everyone know you can do this with the doors really easily, the doors do tend to get in the way a lot with large loads due to their shape
anyone else done this? do the door stop things from a later van fit so i can open the doors like this when i like rather than having to take pins out etc
have a pic of the doors open lots and the hardore coming out...
mike
Image Image Image
mike c
Re: mk2 180degree opening doors
Postby Luke » Fri Dec 12, 2008 11:02 pm
useful to know :D .......... except ive got lift up back doors on mine - so i'm totally stuffed for forktrucks :lol:
Postby Neil » Sat Dec 13, 2008 3:29 pm
theres a spring loaded clip on the inside of each door normally that you press in and that lets them fold right back
Neil v6
Neil
Postby mike c » Sat Dec 13, 2008 5:49 pm
Neil wrote:theres a spring loaded clip on the inside of each door normally that you press in and that lets them fold right back
aye there is on most vans, but not on the mk2, i had a very good look at mine before drilling the pins out and theres no way you can do that
budget lowering at its best!
Image Image Image
mike c
Postby Neil » Sat Dec 13, 2008 7:03 pm
the mk 1 doors do it so they must have changed it
Neil v6
Neil
Postby vannut » Sat Dec 13, 2008 7:03 pm
All the Mk11s I've ever seen have had 180 degree opening doors, as have all the Mk1s, 3,s etc. You just have to pull the spring loaded stops, BUT you can't pull the stops when the doors are open at 90 degrees, you have to pull them back off the stops a little first... :D
Where's me anorak!!!
vannut
Postby vannut » Sun Dec 14, 2008 7:07 pm
Image Image
vannut
Postby Neil » Sun Dec 14, 2008 10:37 pm
every one i ve seens been like that too,just press the clip
Neil v6
Neil
Postby Luke » Sun Dec 14, 2008 10:40 pm
Neil wrote:every one i ve seens been like that too,just press the clip
could it be something to do with it being a minibus :? :?:
Postby Neil » Sun Dec 14, 2008 10:48 pm
dunno but possible,but its all down to the door check,unless they made specials for mini buses closer pictures from mike should solve it :wink:
Neil v6
Neil
Postby mike c » Sun Dec 14, 2008 11:47 pm
i expected to be hugely embarrased after i read this, but having looked again at my closers i stand by what i said first...
the left hand end will definately not fit through the hole in the door.
Mike
Image Image Image
mike c
Return to Mk 1 & 2
cron
