Front Wing replacement
Postby Powertone » Thu Mar 23, 2006 5:52 pm
Hi,
I am thinking of repalcing both front wings on my 1995 smiley transit 2.5di.
How hard a job is this, what does it entail? Are they bolted or welded? If welded how do I get them off?
Is it a job for a garage or can it be done diy?
Powertone
Postby MrMPuk » Thu Mar 23, 2006 6:05 pm
They are welded and the easiest way to remove them is with a spot weld drill. It depends how competent you are as to weather you do them yourself.
Postby FredTransit » Thu Mar 23, 2006 7:02 pm
How bad are they? As wings are not structural it's def a case for filler! :lol: I have seen Mk2 wings held on with self tappers!
FredTransit
Mk2 Trannyist
Postby Powertone » Thu Mar 23, 2006 11:49 pm
Their not really that bad. I suppose they could be filled but I expect it would eat through again pretty sharpish.
Powertone
Postby madmark » Fri Mar 24, 2006 3:15 pm
:shock: filler wont last a few days! it depends if you are keeping the van, the only way to get rid of rust is to cut it out! :)
Users browsing this forum: somename
