Hard times.
Hard times.
Postby SirKit Breaker » Sat Dec 20, 2008 9:53 pm
Evening all,
Dont want to sound dumb but i cant change the time on the dash clock, i`ve pushed pulled twisted the knob, i can the thing to flash but cant advance the time.
Please tell me how or will i need to move to another time zone.
Cheers.................Howard :oops:
GREAT BRITAIN LOVE IT OR LEAVE IT.
SirKit Breaker
Re: Hard times.
Postby local nick » Sat Dec 20, 2008 10:03 pm
aye up. push the lefthand button till the hrs or mins flash then press the righthand button to change the time. hope this helps. :D
local nick
Re: Hard times.
Postby RoAFtech » Sun Dec 21, 2008 12:09 pm
I also tried this yesterday. Got the whole time display to flash (and the milometer went to zero). I could change the minutes but not the hours - do I have to sit there waiting for the diplay to advance minute by minute (nine hours to go)?
Regards,
Steve
Technical Co-ordinator
Romanian Aid Foundation
RoAFtech
Re: Hard times.
Postby Refined Detail » Sun Dec 21, 2008 3:35 pm
Sorry, but for goodness sake, do the obvious thing and read the manual?!!
I can't remember what it is off the top of my head, but know full well that it tells you how to do it in there!
Refined Detail
Re: Hard times.
Postby xpressvalet » Mon Dec 22, 2008 12:33 pm
:lol:
i should laugh, i still use the random button press procedure to reset the trip, now where is that manual ?
i can clean cars for hours n hours, its a condition i've got
xpressvalet
Re: Hard times.
Postby Mylee » Tue Dec 23, 2008 9:04 pm
xpressvalet wrote:i still use the random button press procedure
:D :D :D :D You and every other practical minded guy on the planet! Instructions are for whimps! :D
(or when we must admit defeat!)
Mylee
Re: Hard times.
Postby RoAFtech » Wed Dec 24, 2008 9:48 pm
Refined Detail wrote:Sorry, but for goodness sake, do the obvious thing and read the manual?!!
Mine didn't come with a manual - that's why I asked the forum :? !!!
Anyone know whether the manual is available on-line?
Regards,
Steve
RoAFtech
Re: Hard times.
Postby lightning » Thu Dec 25, 2008 11:37 am
To set the clock, turn on the ignition to position 2 (fully on), press and hold the button to the left of the clock for at least 3 seconds. Then press the button to advance the time a minute at a time. To advance quickly hold the button down. To change between 12 and 24 hour clock, turn ignition to position 1 and press the button to the left of the clock to change between the two.
lightning
Re: Hard times.
Postby dcwuk » Thu Dec 25, 2008 12:18 pm
On my connect
ignition on, press left button once to switch between 12 and 24 hr format .
press and hold left button untill hours flash then adjust the time with the right hand (trip reset) button press left again adjust the minutes with the right button then leave it alone the clock then stops flashing and away you go.
cheers
'I have opinions of my own -- strong opinions -- but I don't always agree with them.'
-George Bush
dcwuk
Re: Hard times.
Postby RoAFtech » Fri Dec 26, 2008 12:24 pm
Thanks guys - I'll try it a bit later.
At the moment the car is under 3 inches of snow and the doors are frozen solid!
Happy Christmas!
Regards,
Steve
RoAFtech
Re: Hard times.
Postby lightning » Fri Jan 16, 2009 6:41 pm
If you've got the later Ford stereo (where the display shows the time) it blocks the clock on the dash. The clock on the dash will appear when you press the button but won't set. Also it won't stay on...when you let go of the button the trip meter comes back on. It sets automatically when you set the clock on the stereo.
lightning
Re: Hard times.
Postby Chalky740 » Fri Jan 16, 2009 7:27 pm
If you want a manual, try eBay, that's where I found one for my Connect, as I didn't have one when I bought my van.
Chalky740
