If anyone knows,I would appreciate it,
Baggers wrote::roll: Hello everyone. This is my first post on this site and I am hoping that someone can help me. I have an 05 MK 6 SWB 125ps and need to know details of the speed pulse signal for vehicle speed. I have bought a Pioneer satnav unit and it requires an input for vehicle speed.I would like to know the best point to tap into the cable and the respective colour coding.
Nighthawk wrote:The dash on yours is the electronic item and the wiring harness isn't that easy to get at and the connector is a small affair.
The speed signal to the dash is sent from the engine management module, it is possible to find the wiring where it comes back through the bulkhead into the cab area.
There used to be a grey plug below the central junction box with a jumper wire in, that was where the tachograph option took it's feed from, not sure if it was left there on later vehicles though.
Once you know the signal from the Vss you can trace the cable back and go from there.
Users browsing this forum: knobby1
