leak off mod????
leak off mod????
Postby escort » Tue Jan 06, 2009 8:50 pm
hi all whats this leak off mod and what exactly does it do ??
want to check see if its been done to mine
cheers
george
escort
Re: leak off mod????
Postby Steve B » Tue Jan 06, 2009 11:23 pm
I`d like to know aswell please
Steve B
Postby AndyG » Tue Jan 06, 2009 11:29 pm
Have you tried a search :?:
sidspop wrote:Image
Front of engine at left. Before mod is top, after mod at bottom. Red shows blanking tits.
Is that ok?
Andy
Postby Steve B » Tue Jan 06, 2009 11:57 pm
Andyg wrote:Have you tried a search :?:
Will do Andy
sidspop wrote:Image
Is that ok?
Andy
Steve B
Postby transexl » Wed Jan 07, 2009 7:04 am
THANKS for picture !!!!!!!!!!!!!!!!!!!!!!!!!!!!
(How about putting this mext to MarkMs "Power-Up" article ? (In "Articles", obviously... :D )
Ans maybe a short "Ball-Bearing"-info ?
Just a thought !
...heinkel statt harley...!
..."TEUTONISCHE-1998-F100-2.5-normallyaspirated-76PS-"banana"-flamestart-diesel-3.89trans-4.11diff-semihighroof-shortwheelbase-twinbackdoors-whitewithblueGT40stripes-"bit"ofrust-mopedtransporting-NOEXTRAS(exeptfortheABS)-205450km-doingsomemaintenanceupdatingandrepairsmyself-fearingbodywork-promptstarting(...)-SMILEY-POWERUPbyMarkM-TRANSE"...
transexl
Location: Mönchengladbach, Germany - near Dutch border luckily....
Postby Frag » Wed Jan 07, 2009 3:27 pm
As a note,when leak off is moved to front injector,pipe must be routed up-hill away from injector to allow air/bubbles to rise away from injector :idea: :!:
Frag
Ford Technician
Postby Aardvark » Wed Jan 07, 2009 5:44 pm
So is anyone gonna tell us what its about? Mine hasn't been done. So will I turn into a pumpkin or something?
Or is it another thing causing my di to not start easily?
Learning to love rust.........
Aardvark
Postby Frag » Wed Jan 07, 2009 6:31 pm
Symptom is miss-fire on 1 cylinder caused by air-lock on top of injector,usually no.1.
Crack that injector, fault clears.
Leak off point is moved to highest point where air gathers,No1 injector,routeing pipe uphill-away from injector allows air to rise away & back to tank.....
Frag
Ford Technician
Postby sideshow_bill » Wed Jan 07, 2009 7:22 pm
Frag wrote:Symptom is miss-fire on 1 cylinder caused by air-lock on top of injector,usually no.1.
Does this miss-fire occur on startup or when running?
sideshow_bill
Postby redeemer » Fri Jan 09, 2009 10:30 pm
On which engine and with which pump this is most likley to happen?
I m keen on knowing more about this...
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Postby Frag » Fri Jan 09, 2009 11:52 pm
Later mk5`s i.i.r.c,bosch pump,think it started around time filter head changed to one with screw on locking ring :? :?:
Frag
Ford Technician
Postby MinorMatt » Sat Jan 10, 2009 12:15 am
N reg ('95) - old type
Postby Dave F. » Sat Jan 10, 2009 1:18 am
Guys, you have just answered my question before I could even ask!! I've got a 98 transit with the later type locking ring filter housing and it's displaying all the symptoms as above... When you drive along and take your foot off the throttle to slow up, the van suddenly begins misfiring. Crack off the injector pipes, its cleared again...
Dave F.
Postby alanwh » Sat Jan 10, 2009 11:01 am
it's a good idea to renew leak off pipes while you're at it, it's only a few quid a roll (even seen it in Halfords!!) and the pipes don't last more than a couple of years before needing to be replaced. They may look ok at first glance, but inspect under the braiding and you may well find they're in a perished state.
alanwh
Postby transexl » Mon Jan 12, 2009 7:06 am
...so - does it really suck in via the leak-off ?
I do not quite yet get what is needed to fix it: the filter AND the new leak-off pipes/mod ???
(This is NOT about the money. Just curious !)
Are there any more leaks ?
transexl
