Speedo cable and wing mirrors
Postby Andrewb » Tue Jan 13, 2009 12:07 pm
Hi,
I came to connect my speedo cable to the new type 9 last week, and its just too short. Can anyone suggest a car which had a slightly longer one that will fit, or even let me know length of the mk1 transit one ( I'm away from it at the momment).
Also wondered where people get replacement wingmirror glass for mk1's (1971)?
Thanks for your help,
Andrew
Andrewb
Re: Speedo cable and wing mirrors
Postby foggy08 » Tue Jan 13, 2009 12:33 pm
sorry cant help with speedo,but halfords used to have a mirror glass ( plastic ) that you cut to size.i know its not original but will get an mot and do till you find one on ebay
ouch ..suarez bit my finger
foggy08
Postby Andrewb » Tue Jan 13, 2009 1:09 pm
Thanks Foggy, thats sounds just what I need for the time being.
Andrew
Andrewb
Postby MK1Chris » Tue Jan 13, 2009 1:26 pm
You could try Tex Automotive for replacement mirrors. Link: http://www.texautomotive.com/classic_mirror_heads.html
I think they supply replacement heads with glass fitted, but might be worth giving them a ring to discuss your requirements.
MK1 CI Motorhome.
Original 2Litre V4 and 4 Speed Manual with 29k on the clock (now up to 31k!)
Rusty problems soon to be sorted. See my progress in the projects section... http://fordtransit.org/forum/viewtopic.php?f=27&t=28696
MK1Chris
Postby Luke » Tue Jan 13, 2009 6:52 pm
well ive got a type 9 on a mk1 and the cable was one i had so im guessing its either transit mk3 or sierra :D
Postby madmark » Tue Jan 13, 2009 7:38 pm
if you want to keep the original look you will need tex replacement mirror
M50101
Convex Glass
its good these are still made! 8) 8)
a mk1 just aint a mk1 without the corect mirrors on the wings! :wink:
Postby MinorMatt » Tue Jan 13, 2009 11:20 pm
Andrew
Dunno how good this info is.... but I have here a speedo cable for MK3 1600/2000 cortina RHD 70-74 (well thats what it says on the label)
The part no (moprod) is MSD523 and compares to Surespeed 790/83.
Its 83.5 inches long and has the right ends
Typically the little section on the box which gives other part nos and lengths for the cables with the same ends has abraided off :(
Postby Andrewb » Wed Jan 14, 2009 4:11 pm
Thanks for the replies, think I'll probably give tex a try.
Andrewb
Return to Mk 1 & 2
