Need 'em big, fatter the better..
Postby chrisuk » Tue Mar 28, 2006 10:48 pm
Not what you think it is, this is about wheels and I need them as wide as I can possibly go (forget UK law), anyone have clues/ideas what other vehicle rims would fit ie: Landrover etc, The reason Im asking is because I need them for a demanding roll where the terrain is sandy and muddy, I knw its not a 4x4x far but thats not the issue right now, any ideas or comments greatly appreciated.
Steel rims preffered, alloys wont take the punishment
chrisuk
Postby rover » Wed Mar 29, 2006 8:37 am
Landrover wheels wont fit Chris, the Transit PCD is 160mm the Landrover is 165mm, although you may be able to get a set re-drilled to fit.
Rover.
rover
Postby Luke » Wed Mar 29, 2006 7:08 pm
what about fitting landrover tyres to your transit wheels :?:
can it be done :?:
Postby chrisuk » Wed Mar 29, 2006 7:30 pm
Luke wrote:what about fitting landrover tyres to your transit wheels :?:
can it be done :?:
Im sure they can be but clearance on the rear inside wheel arch is not much but yes Im sure they will fit, I suppose I could always fit spacers on the studs to bring te rim out a tad bit as clearance is not much and at a guess around 2 1/2" max, going out is not a problem
chrisuk
