heater fan
heater fan
Postby hodgson4711 » Mon Jan 05, 2009 5:18 pm
is it possible to glue a fan blade on the heater together again useing plastic araldite. would the spining cause it to break away. regards dave
hodgson4711
Re: heater fan
Postby Neil » Mon Jan 05, 2009 7:26 pm
should last a few days
Neil v6
Neil
Re: heater fan
Postby redeemer » Mon Jan 05, 2009 8:33 pm
Use an electirc solder to melt the plastic , and try to weld it again! and if you can put a reinforcing wire across the crack in U shape. Thats what solved my problem for a broken plastic piece which holds the high tension wire on a Britsh seagul outboard motor.(they are obsolete) :wink:
Best soliution is to fit another propeler.
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Re: heater fan
Postby baconsdozen » Tue Jan 06, 2009 9:28 am
Although maybe not the answer in this case I've found that the clear silicone sealer (I use the draper one) is one of the only things that will stick to the softer plastics.You can also use a bit of plasic like one of those plastic ties as a sort of welding filler using a soldering iron.
baconsdozen
Re: heater fan
Postby hodgson4711 » Sun Jan 11, 2009 3:25 am
thanks for the ideas. i've melted the plastic on the fan blades and stuck them togerther and used the wire ties as a joining seal to stick them together, it seems to hold . i can lift the motor up using the broken blade and it feels as strong as all the other blades. i'll run it tommorrow for a long period and if it has no problem fit it back in tommorrow. thanks again :lol:
hodgson4711
Re: heater fan
Postby hodgson4711 » Thu Jan 15, 2009 2:00 am
just a update the fan is working perfectly best i've ever had it in the past eight years! i am still looking for a 4.63 diff if anyone has one or knows where i can get one. regards dave :lol:
hodgson4711
Return to Mk 1 & 2
