[url]
http://www.apec-braking.co.uk/apec_deta ... ansit+Van+[95-00]&model=Transit+80+%2F+100+%2F+120+1%2F95-10%2F00&partno=DRM+9712++[/url]
Drum Diameter 254.0mm
Maximum diameter 255.5mm
Drum width 57.5mm
Outside diameter 292.0mm
Overall height 96.0mm
Transporter
[url]http://www.apec-braking.co.uk/apec_detail.asp?manufacturer=VOLKSWAGEN&range=Transporter+T3+[86-90]&model=Transporter+1.6+1%2F86-1%2F90&partno=DRM+9700++[/url]
Mountings 5
Drum Diameter 252.0mm
Maximum diameter 253.5mm
Drum width 64.0mm
Outside diameter 286.0mm
Overall height 78.0mm
So.... VW drum is 2mm less in internal dia - could be skimmed out?
The friction surface is 6.5mm wider - not ideal but okay
O/D - Transit drum is 8mm wider
Overall height - Transit drum is 18mm deeper
