especially if your not getting any other injector rattle or power problems
Madmorris wrote:Well, I have read through this thread. Sounds so familiar. I had exactly the same symptoms on my '06 125ps 280 with about 125k miles on it.
4 new injectors seemed to cure the problem but now, 5k later the slight hesitancy, increased fuel consumption and slight rough cold idle has come back.
Yesterday, however it all got much worse. Started ok in the morning but when I went to pull away, no power at all and it stalled. Now will not rev at all.
Tried to see if there were any codes stored using the dash (since ford diesels don't seem to work with OBDs). Nothing there! Local bloke who works of Fords came out and says the injector pump has gone now. £1k to replace! EEEEEK!
Why I ever changed from my old DI I don't know. The guy up the road that got it off me for £200 is still running it.
Dave.
