Low Power
Postby gemini » Sat Apr 01, 2006 6:18 pm
ive had an ex bt before and it wasnt restricted, you said it has low compression on no. 1 & 2 cylinders, what was the pressure and how quick did it get there
gemini
Postby Guy88 » Sat Apr 01, 2006 6:38 pm
Compressions were:
Cylinder 1 - 26 bar
Cylinder 2 - 28 bar
Cylinder 3 - 36 bar
Cylinder 4 - 37 bar
Not sure how quickly it got there
Guy88
Postby Luke » Sat Apr 01, 2006 6:54 pm
Guy88 wrote:Compressions were:
Cylinder 1 - 26 bar
Cylinder 2 - 28 bar
Cylinder 3 - 36 bar
Cylinder 4 - 37 bar
whats that in psi :oops:
Postby daddy cool » Sat Apr 01, 2006 7:00 pm
1 bar is roughly 14.5 psi :wink:
Even if you don't need it, grab it.
The minute you do need it, it'll be gone.
daddy cool
Postby gemini » Sat Apr 01, 2006 7:10 pm
have you had the head pressure tested??, are you sure there are no hairline cracks in the pistons
gemini
Postby Guy88 » Sat Apr 01, 2006 7:16 pm
Head was tested by proffesional who said that he couldn't find any cracks he also said it wasn't warped.
couldnt see any cracks in pistons and i also filled the cylinders with oil and they didnt go down, i have also checked the valves and they all seem OK
Guy88
Postby gemini » Sat Apr 01, 2006 7:18 pm
oil wont go down try a bit of petrol see if it sits on top
gemini
Postby Luke » Sat Apr 01, 2006 7:19 pm
Cylinder 1 - 377 psi
Cylinder 2 - 406 psi
Cylinder 3 - 522 psi
Cylinder 4 - 536 psi
certanly looks like a problem between 1 and 2 :shock:
does the problem occur when its hot only?
Postby Guy88 » Sat Apr 01, 2006 7:30 pm
gemini wrote:oil wont go down try a bit of petrol see if it sits on top
This was very thin machine oil
The van is generally gutless and very difficult to start in the cold and sits there pumping out white smoke before finaly springing into life
Guy88
Postby gemini » Sat Apr 01, 2006 7:49 pm
still wont be able to tell with oil
gemini
Postby 100ps_drw_hicube » Sat Apr 01, 2006 7:51 pm
put some derv in that seems to work ok :)
100ps_drw_hicube
Transit Abuser!!
Postby madmark » Sat Apr 01, 2006 7:52 pm
di,s do tend to fume out of the rocker cover if its running on thin oil, also as 100ps says have you pulled the dipstick out when its running ,if its fumeing out of there then you have ring problems, but very unlikely for the miles the van has done! maybe a pump falt if its smokeing ,has the cambelt been done is the timeing correct?????,this will make it smoke and underpowerd if its not! :wink:
Postby Guy88 » Sat Apr 01, 2006 8:07 pm
There is nothing out the dipstick hole. i have just got it started again and tested it and it seems to warm up quicker and a slight improvment but not a lot. i am going to check the timing later and get the injectors tested
Guy88
Postby madmark » Sat Apr 01, 2006 8:22 pm
:? some di,s dont like running on the correct timeing ,you have to play around with it to get it perfect! :?
Postby 100ps_drw_hicube » Sat Apr 01, 2006 8:25 pm
have you checked the tappets as if there out they dont like starting :?
100ps_drw_hicube
Transit Abuser!!
