oh yes i'm getting serious
the van will DEFINATLY be getting a full waxoiling
i'm just waiting for the weather to warm a bit, the van hasn't moved the whole winter so no driving around untll all the salt has gone
getting used to this woodworking lark
at least ive found a use for all the drill bits i couldn't be arsed to sharpen
i'm pritty chuffed with all the joints etc. but you still find things you wish you'd done differently - like the right side bed runner i cut it square at the end and the joint is an angle, you can see what i mean in the last 2 pics
here's some pics while i have a cuppa and a break
the bit at the end needs cutting - i deliberatly left it long till i got the angle 100% i think i'll be able to cut it off in situ with the jigsaw (i need to go borrow it).
i was origanally going to have the wall behind the rear seat tilting back to make it more comftable to sit on but i think most of the time the seat will be used for eating at the table so i made it vertical - makes it easier to build aswell
close up of the joint - all bolted in as this needs to hold the weight of the bed and although it's designed for a child i want it to be able to hold an adult as it's 6' long
i had to recess the bolts as the wall board will be fastened flush to that bit
the pics from the back show the storage area under the bed - one of the main advantaged to this layout plenty of storage space
it looks like its not straight as its not bolted at the top yet - when it's done it will be right
