100ps engine swap
Postby 100ps_drw_hicube » Wed Apr 05, 2006 10:46 pm
Nighthawk wrote:I've never seen a sensor below the starter on a Di :shock:
The only sensor down there should be the crankshaft position sensor and thats above the starter up below the fuel filter, it slides into the hole used for the crank pin.
:oops: :oops: your right looking at my pics its below fuel filter is this sensor needed as my current van aint got one :? :?
oh and after today i have decided im definately going to need an engine lift it took 3 of us to try a drag the thing into my garage :x i swear it looked easy when it was being forked onto the other van :lol: :lol:
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Wed Apr 05, 2006 11:00 pm
Just had another look in the dark with a torch....I've got a sensor that I presume is the oil pressure switch, nearest me, and the one further away(next to it) from me (nearer the starter motor) has a tube connected to it which strangely goes to the back of my alternator's vacuum unit :? I guess if you don't have that alternator you could try blanking it off :?: I'll look into this a bit further if I can :wink: :?
Postby Luke » Wed Apr 05, 2006 11:03 pm
Andyg wrote: has a tube connected to it which strangely goes to the back of my alternator's vacuum unit :?
isnt that the oil feed or retrurn :?:
Postby 100ps_drw_hicube » Wed Apr 05, 2006 11:03 pm
cheers mate i dont want to get halfway thru this to find theres gonna be loads of probs i want to get in asap 8) will steam clean engine tommorow and belt it up then just a case of ditching all that intake manifold and swapping it for mine :)
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Wed Apr 05, 2006 11:13 pm
Could it be lubrication for the vacuum unit :?: And how come the older ones didn't need this :?: :?
Postby gemini » Thu Apr 06, 2006 1:04 am
you need a square frame with some wheels on from a shopping trolley to wheel them about
gemini
Postby jay » Thu Apr 06, 2006 4:12 pm
or a fork lift to move them around..
mk1 connect tourneo
jay
Postby 100ps_drw_hicube » Thu Apr 06, 2006 4:27 pm
problem is space is tight and dont have access to a fork lift :( have made a temporary cart to move it about 8) just got to get a lift to put it in :?
100ps_drw_hicube
Transit Abuser!!
Postby 100ps_drw_hicube » Thu Apr 06, 2006 5:43 pm
:oops: :oops: i made this bike trailer when i was 14 :lol: :lol: just proves i over engineer things :lol: :lol:
at least i can move the engine about now 8) i have given it a good degrease today have just put a load more on and will wash it in the morning :)
100ps_drw_hicube
Transit Abuser!!
Postby gemini » Thu Apr 06, 2006 7:15 pm
have you took the old one out yet, i find it easier when fitting an engine to drop the engine & box in together
gemini
Postby 100ps_drw_hicube » Thu Apr 06, 2006 8:14 pm
gemini wrote:have you took the old one out yet, i find it easier when fitting an engine to drop the engine & box in together
no mate she's still in if you think that will ber easier then i might try that as it looks quite a precise job lining up all these holes :shock:
100ps_drw_hicube
Transit Abuser!!
Postby Nighthawk » Thu Apr 06, 2006 8:34 pm
M8, if you have an epic equipped engine in your van now......it has a CKP (crank) sensor. It won't run without it :wink:
Nighthawk
Postby gemini » Thu Apr 06, 2006 8:34 pm
thats how i do it, hang the engine so the gearbox is slightly pointing downwards drop it in and put a jack under the box as it goes through the bulkhead, drop the engine mounts on and lift the gearbox into position, saves alot of hassle trying to line it up
gemini
Postby 100ps_drw_hicube » Thu Apr 06, 2006 8:37 pm
Nighthawk wrote:M8, if you have an epic equipped engine in your van now......it has a CKP (crank) sensor. It won't run without it :wink:
maybe thats why it dont run :lol: :lol: ok maybe its hidden by all the extra police wiring :roll: :roll:
100ps_drw_hicube
Transit Abuser!!
Postby ryzman » Thu Apr 06, 2006 9:47 pm
i would be putting a bosch pump on this engine whilst its out don't need to worry bout silly sensors feel free to try my van out if your passing through
[color=#4040BF]umm nice mk6.. 85ps swb l/r executive... hybrid turbo.. modded injectors... decat... 225/70/r15 tyres... remap by van tuner... loads of torque... lovely jubley
ryzman
