Cambelt tensioner.
Postby Nighthawk » Tue Apr 04, 2006 8:03 pm
Nice work there Mike 8)
The best way to get a viscous hub off is to use a hammer and prybar, with the fanbelt still in place holding the pulley tight, locate the prybar on of the central BIG nut's flats, and give it a whack. If you get it right the nut will undo and you'll be able to spin the hub off with your fingers. It can even be tightened the same way.
there is plenty of room do the belt with the rad and slam panel in place. :lol:
Nighthawk
Postby crazyscoot » Tue Apr 04, 2006 10:16 pm
MrMPuk wrote:I did remove the fan, undo the 4 bolts on the front that bolt the fan to the viscous coupling and then it should just pull off. You can also remove the 4 bolts that hold the pulley on behind the fan as that makes it easier to get the cambelt cover off.
Argh! got ya! That would have made it a dam site more easy than the way i did it on Sunday! Then again it was chuckin it down and blowing a gale! not a nice job to do in those condidtions
Negative reality inversion
crazyscoot
Postby MrMPuk » Thu Apr 06, 2006 4:47 pm
Sat down and had a closer look at the old tensioner today and the reason for failure wasn't bearings but the the spring on the back!
THE WAY I DO IT
Postby john leeman » Thu Apr 06, 2006 5:31 pm
DRAIN COOLANT, RAD OFF, GRILLE OFF, Inc SLAM PANEL, FAN OFF ,THE WAY AS ABOVE, WITH A SMALL LONG SHARP CHISEL ON THE NUT, RIGHT HAND THRED, TIMING COVER OFF, THREE TIMING PEGS INSERTED, OLD BELT OFF NEW TENSIONING DEVICE ON,[ THE ONE WITH A SPRING IN & ALLEN KEY SETTING ] NEW BELT ON,. REASEMBLE EASY PEASY.
35 years of driving,repairing,sleeping in transit's lovin every minute.
john leeman
Re: THE WAY I DO IT
Postby Luke » Thu Apr 06, 2006 6:00 pm
john leeman wrote:DRAIN COOLANT, RAD OFF, GRILLE OFF, Inc SLAM PANEL, FAN OFF ,THE WAY AS ABOVE, WITH A SMALL LONG SHARP CHISEL ON THE NUT, RIGHT HAND THRED, TIMING COVER OFF, THREE TIMING PEGS INSERTED, OLD BELT OFF NEW TENSIONING DEVICE ON,[ THE ONE WITH A SPRING IN & ALLEN KEY SETTING ] NEW BELT ON,. REASEMBLE EASY PEASY.
sounds like you've done the job before john :lol:
Postby climbingchris » Thu May 11, 2006 12:10 pm
Right might have to have a go then.
climbingchris
Postby Transitwalla » Thu May 11, 2006 1:12 pm
climbingchris wrote:Right might have to have a go then.
Have a go :) it aint that hard :wink: If your not sure what your doing take your time :) If something wont fit there's a reason why. . . go away and think about it over a cup of tea - coffee - can of beer. Things seem to go better when your not :x
That feeling you get when you've finished . . . . is great . . . next best thing to sex :) . . .
Oh and driving a Transit of course :wink:
Imagination....our only limit....
there's no such thing as a daft question.
Jim.
Transitwalla
