rear output seal for OD gearbox
Postby rottie_007 » Sat Feb 21, 2009 1:46 am
as in title I need the rear oil seal for hte output shaft of my overdrive gearbox
van is T reg mk2
1979 mk2 pre facelift CI campervan " Bessie Brown "
1994 Pug 405 est " George "
1998 pug 106 "Mildred"
rottie_007
Re: rear output seal for OD gearbox
Postby doggypaddle » Tue Feb 24, 2009 10:40 am
just take the old one to worcester bearings, or BSL or any bearing supplier?
doggypaddle
Postby MK1Chris » Tue Feb 24, 2009 2:18 pm
I bought one for my MK1 4 speed (non-overdrive) from Ford.
They can still source these so will probably be able to find one for your 'modern' box!
Think I paid about £7.50 for mine.
MK1 CI Motorhome.
Original 2Litre V4 and 4 Speed Manual with 29k on the clock (now up to 31k!)
Rusty problems soon to be sorted. See my progress in the projects section... http://fordtransit.org/forum/viewtopic.php?f=27&t=28696
MK1Chris
Postby rottie_007 » Wed Feb 25, 2009 12:07 am
ahh thats good news then...
tkae it I can just undo the bolt and pull the output flange off?????
or is it pre-loaded and needs a collapsible spacer or something as well??
rottie_007
Postby MK1Chris » Wed Feb 25, 2009 10:02 am
Errrr....you'd better ask the mechanic who did it for me :oops: :oops: :lol:
I'm sure somebody will be along soon with some helpful advice :D
MK1 CI Motorhome.
MK1Chris
Postby rottie_007 » Sat Feb 28, 2009 7:54 pm
cheers Chris..
currently sitting here going through the haynes manual to see how bad a job it is....
rottie_007
Return to Mk 1 & 2
