injector pump conversion ... HELP!!!
Postby BanditUK » Sat Apr 08, 2006 1:25 am
gemini wrote:thats the earlier bosch pump with the cold start on
so is it chipped??
I'm gettin all confused now :lol: :?
BanditUK
Postby gemini » Sat Apr 08, 2006 1:49 am
no
gemini
Postby BanditUK » Sat Apr 08, 2006 10:28 am
gemini wrote:no
oh
one last question then what are these wires on the back for?
are they gonna cause me any bother and if so, how can i sort it
BanditUK
Postby gemini » Sat Apr 08, 2006 11:52 am
the wire is to the fuel shut off solenoid and will need connecting
gemini
Postby BanditUK » Sat Apr 08, 2006 12:27 pm
gemini wrote:the wire is to the fuel shut off solenoid and will need connecting
Excellent
thanks to you and everyone else for your help
saved me a load of worry :wink:
Mike
BanditUK
Postby FredTransit » Sat Apr 08, 2006 2:54 pm
BanditUK wrote:there are 3 sets of numbers on it which are
1st n.r 0460 414 083, 2nd v.e.r 415 ,3rd 015 463 3171
if that 415 bit of the code is what I think it is, and it's original to the engine, you have the best engine for top end. It's the one most commonly fitted to crew/chassis cabs destined to be tippers. My mechanic has another customer who spent £1,500 haveing a 415 engine rebuilt, it was so good.
FredTransit
Mk2 Trannyist
Postby BanditUK » Sat Apr 08, 2006 4:22 pm
nice nice thats what i like to hear lol
but goin on my engine, so will that change the performance??
BanditUK
Postby FredTransit » Sat Apr 08, 2006 5:15 pm
I don't think you will notice any change to the performance, is the replacement pump a different code to the original? If so I would say do the injectors to match, though some would say it will be OK with the injectors you have. Try the original injectors first, then if you have any probs, change them to match the new pump.
FredTransit
Mk2 Trannyist
Postby BanditUK » Sat Apr 08, 2006 5:17 pm
FredTransit wrote:I don't think you will notice any change to the performance, is the replacement pump a different code to the original? If so I would say do the injectors to match, though some would say it will be OK with the injectors you have. Try the original injectors first, then if you have any probs, change them to match the new pump.
thanks bud will do ;)
never thought about having to change injectors to suit the pump. :roll:
BanditUK
Postby FredTransit » Sat Apr 08, 2006 5:30 pm
I was told the Bosch pumps can be a bit picky, but others on the forum say it doesn't matter.
FredTransit
Mk2 Trannyist
Postby jay » Sat Apr 08, 2006 5:40 pm
the worst bit i get from mine is if i floor it at 30 mph in 4th i get a bit of black smoke from the exhaust and a bit of black smoke on start up but thats the cold start...
mk1 connect tourneo
jay
Postby FredTransit » Sat Apr 08, 2006 5:42 pm
jay wrote:the worst bit i get from mine is if i floor it at 30 mph in 4th i get a bit of black smoke from the exhaust and a bit of black smoke on start up but thats the cold start...
Did you change the pump and not the injectors?
FredTransit
Mk2 Trannyist
Postby jay » Sat Apr 08, 2006 8:41 pm
yeah i changed the injectors..as i got the pump and injectors done together so they are matched...I believe the injection specialist put diffrent nozzles and pintles ends on the injectors...
mk1 connect tourneo
jay
