two stroke oil in the diesel ?
Re: two stroke oil in the diesel ?
Postby Gavin » Sat Dec 27, 2008 11:52 am
also you'd want premix oil rather than injector
Gavin
Postby apexer » Wed Jan 21, 2009 10:40 pm
i have tried this and it seems to work had it tested and got a reading of 1.85 on a quick pass test have done 2000 miles with 2 stroke in the tank mpg has gone up by about 3 mpg there is far far less visable soot when the engine is redlined and the quick pass test gave a reading of 1.13 so thumbs up all the way
apexer
Postby jolly olly » Wed Jan 21, 2009 11:23 pm
What model you running.
Life is not a dress rehearsal
jolly olly
Postby darkbluevanman » Wed Jan 21, 2009 11:34 pm
Yup, I'll give it a thumbs up deffo seems a bit quieter and smoother, espec' on cold start...
darkbluevanman
Postby bortaf » Thu Jan 22, 2009 1:23 am
New cooking oil does the same in my wedge, i usually mix in 25% new oil, quicker, quieter (especialy on cold start) better MPG :D
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby winterheating » Thu Jan 22, 2009 1:35 am
if it cuts down the carbon output it has to be good, stops the turbo, cat and full exhaust system getting carbon-ed up, INCLUDING EGR and INTAKE manifold :!: :D
winterheating
Postby linus » Thu Jan 22, 2009 10:56 am
I have been testing it for over 2000 Km now and confirm smooth running engine, using 0,5 l/100Km less diesel and the diesel pump is better lubrificated.
Linus
Life's too cheap to drink short wine.
Peace
linus
Postby Gavin » Mon Mar 16, 2009 10:17 pm
done about 3 tanks now with cheapy carplan 2stroke oil in the mix, definately smoother and quiter and more pokey and havent had any of that rough running / air in fuel (sticking injectors?) since, despite it beeing a weekly problem before.
Gavin
Postby barabas » Fri Apr 24, 2009 6:45 pm
1st tankful (68l) + 300ml 2 stroke in '96 100S Low roof, half load, some Mway, mostly A/B roads with b4stard steep Devon hills all @ 60mph max : 35 mpg... 8) Will report on subsequent tankfuls, both with and without 2 stroke.
The two most common elements in the universe are hydrogen and stupidity.
barabas
Postby toniel » Mon Apr 27, 2009 11:57 am
This looks very interesting and I think I will give it a go.
Is anyone out there using 2 stroke oil and acetone?
I am trying the acetone experiment at the moment, but it will be mid summer before I can post any meaningful accurate MPG results owing to the infrequent use of the vehicle.
>> My second home is a Tranny <<
toniel
Postby merseycool » Mon Apr 27, 2009 1:02 pm
I run an old Bedford TK on 2 stroke oil mixed with the fuel and more recently a modern Scania and have been putting oil in the diesel for years and touch wood I have never had any problems with engines or the fuel pumps. It's tried and tested go for it but do remember only in small amounts when filling up the tank :wink:
jolly olly wrote:Just copied and pasted this from the other site hope it makes sence to some one, so if your brave enough to try it let us know the out come.
The quote.
I would use any of the two 2-T oils, whichever I would get cheaper.
You can also use the Mobil Extra 2T.
Important is, that those 2T-oils should comply with JASCO "FC" or ISO L-E "GC" or "GD", which should be written on the bottle. All 2T-oils as per these norms burn with an ash content of less than 0,05%.
merseycool
Postby Altransit » Mon Apr 27, 2009 1:13 pm
toniel wrote:Is anyone out there using 2 stroke oil and acetone?
Yes, I am. Very good results so far :D
Postby cabbage » Mon Apr 27, 2009 2:28 pm
What ratios are you using? And how long have you been using them together?
Thanks,
Cabbage
cabbage
Postby Altransit » Mon Apr 27, 2009 2:32 pm
cabbage wrote: What ratios are you using? And how long have you been using them together?
300ml of 2 stroke, 30ml acetone, per 60 litres of diesel fuel
I've been using it for a couple of months, but not continuously :wink:
Postby cabbage » Mon Apr 27, 2009 2:35 pm
cabbage
