FORD TRANSIT HICUBE 1998Y. 101PS - OPINIONS ----------
Postby ivan_will » Fri Mar 20, 2009 11:26 am
Greetings,
Could you please say some opinions about this model? What about the engine? Is it reliable? other...
Thanks in advance!
ivan_will
Re: Ford Transit HiCube -1998 101PS - opinions
Postby BigNeil » Fri Mar 20, 2009 12:03 pm
hicube are great as they are very big inside
used to have a longcube which was same length but had a semi high roof
the engine is different to what i had so you need to wait on someone else to advise you about that
is this one you are about to buy ?
BigNeil
Postby alanwh » Fri Mar 20, 2009 1:10 pm
A 100ps Turbo ?
alanwh
Postby ivan_will » Fri Mar 20, 2009 1:50 pm
Yes , I think ... :)
I don't like that these models have rust ...
but... I've heard that the new models(from 2000y.) aren't good enough...
give me an advice ....
ivan_will
Postby alanwh » Fri Mar 20, 2009 2:59 pm
Rust a lot less than a sprinter :roll:
MK 5 2.5 DI Engine (quite noisy) but bullet proof, because of this are also abused to hell and back :!:
With the TD. They are the first generation electronic "fly by wire" accelerator pedal and pump and have a bad reputation for failing (mostly unjustified). Make sure that the engine management light comes on with the ignition and goes out straightaway on start up and doesn't come on at all throughout the test run. You will need to give it a long run to make sure its right up to max operating temp. It should rev well without hesitation and without much smoke. While idling, any "hunting" does tend to point to injection system problems.
Get a good one, service it well, then learn to weld and you will never need another van :D
alanwh
Postby ivan_will » Fri Mar 20, 2009 3:07 pm
Thanks for...the info!
I've forget to say that the model I want to buy has four wheel back!
Could you give me an information how much is the payload?
ivan_will
Postby ivan_will » Fri Mar 20, 2009 5:53 pm
This is the van!
ivan_will
Postby alanwh » Fri Mar 20, 2009 5:55 pm
Nice one :!: Looks in great nick, how much is he asking for it ?
alanwh
Postby ivan_will » Fri Mar 20, 2009 6:01 pm
4000EUR in Bulgaria ..I'm comin from Bulgaria!
ivan_will
Postby bazw » Fri Mar 20, 2009 6:09 pm
where are you in bulgaria ? i will be in bansko and pleven areas in june
i have this engine minus fly by wire injection in my sprinter which is about the same size as the high cube and most of the time it has been great , good economy when i try for it or fast if i dont
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby alanwh » Fri Mar 20, 2009 6:13 pm
JESUS...How much :!: :!: :!: :?: :?: :?:
Can't you get one from the UK and convert it to L/H drive ?
Off the top of my head, I would think a really good one would only be £1500 in the UK
alanwh
Postby madmark » Fri Mar 20, 2009 6:18 pm
thats a very nice van ,overhere you wont find that nice condtion very much! :wink:
Postby ivan_will » Sat Mar 21, 2009 12:34 pm
any ideas how munch is the payload? :? :?:
ivan_will
Postby ivan_will » Sat Mar 21, 2009 12:37 pm
This is another van ...the same like the previous...
please tell me about the payload of this van???? !!!!!
ivan_will
Re: FORD TRANSIT HICUBE 1998Y. 101PS - OPINIONS ----------
Postby MinorMatt » Sat Mar 21, 2009 12:44 pm
well it will either be a 190 (3500kg max gross weigh - 1700kg approx payload) or a 230 (4250kg Max gross and about 2300kg payload)
You would need to look at the data plate in the passenger step to know for certain
Return to Buyers Guide
