Advice needed
Postby Luke » Fri Apr 14, 2006 10:28 pm
100ps_drw_hicube wrote:i think luke is fitting a 16v ?? :?
not anymore mate V624v cossy for me :twisted: :lol:
although i can see me pulling the 24v out after a while (fuel bills) and sticking a 2.0DOHC 16v in :lol: which was my origanal idea!!! :roll:
Postby 100ps_drw_hicube » Fri Apr 14, 2006 10:33 pm
tight northerners !!:roll: :roll: :lol: :lol:
100ps_drw_hicube
Transit Abuser!!
Postby MWOOLY10 » Fri Apr 14, 2006 10:35 pm
So the 16v will fit the same as an 8v will then Luke?
Quick question if its one of my valves that are bent could i take the top head off my 2ltr 16v Scorpio and fit it to my 2ltr 8v Transit??
Cheers Mike
MWOOLY10
Postby MWOOLY10 » Fri Apr 14, 2006 10:40 pm
Would of liked to have put a bigger engine in myself but i spend enough on fuel as it is .. Dont wanna be spending anymore :lol:
Cheers Mike
MWOOLY10
Postby Luke » Fri Apr 14, 2006 10:40 pm
MWOOLY10 wrote:So the 16v will fit the same as an 8v will then Luke?
aparrantly so :!: - i'd imagaine its not as strait forward as that tho some pulleys on the block etc. and almost certanly some wiring to be done!! :?
my origanal plan was to buy a scrap 2.0 16v scorpio and use the full engine and wiring loom!!! :D
Postby MWOOLY10 » Fri Apr 14, 2006 10:43 pm
I would use the full engine but the crank is knackered on the Scorpio one..and for what it'd cost to fix i could buy another car to get a donor from :lol:
Either that or just nick a valve out of it..or whatever it is thats tapping
Cheers Mike
MWOOLY10
Postby Luke » Fri Apr 14, 2006 10:47 pm
i'd reckon the easyest way would be to fit the dohc 8v crank to the 16v .................. be a bit of a bummer if it was different tho :? :lol:
personally i'd go for that job over a head swap :shock: :D
Postby MWOOLY10 » Fri Apr 14, 2006 10:49 pm
Never thought about it that way round :)
May have to think about that when ive had a good look...But i would of though a head swap would of been the easier option IMO :?
Cheers Mike
MWOOLY10
Postby Luke » Fri Apr 14, 2006 10:53 pm
MWOOLY10 wrote:But i would of though a head swap would of been the easier option IMO :?
mabe - you'd still need to get the timing chain off the front i suppose :? - worth considering tho!!! :idea: :lol:
Postby MWOOLY10 » Fri Apr 14, 2006 10:55 pm
Maybe you were right about the crank after all :lol:
Cheers Mike
MWOOLY10
Postby MWOOLY10 » Mon Apr 17, 2006 12:56 pm
crazyscoot wrote:Try the old wooden stick trick :roll: wooden stick, one end in your ear the other end on different places on the engine, You'll be amazed what you can hear through a wooden stick :cry: When you think you can hear that knocking getting louder as you move the stick around the engine, then you know your going in the right direction
Right well done the wooden spoon bit..my engine knowledge isnt great so here goes :lol: Its coming from the bottom end of the engine(it looks like a sports cap but upside down) it gets louder when i listen to the bit that cups down .. I did think it was at the top but after doing that test i was wrong as usual .. Theres a bit of oil around there(doesnt seem to be leaking though) cant hear that bad anywhere else so i presume thats where its coming from..Now would be why im losing power every now an then and when i put my foot down it seems like its missing would this be why??
Cheers Mike
MWOOLY10
Postby crazyscoot » Mon Apr 17, 2006 2:17 pm
The stick trick is a bit heath robinson but it can point you in the right direction......if you know how the different parts sound in the first place. Some parts sound horriffic to listen to but is a perfectly normal sound for that part. So a little knowledge of the internal parts is a big help ie listen to a water pump whirring round, if its making a grinding or knocking sound then you know its that. Good luck and keep us posted :)
Negative reality inversion
crazyscoot
Postby MWOOLY10 » Mon May 08, 2006 9:43 pm
Well it took me 5 hrs :lol: But the engines out .. So tomorrow need to get the one out of the Granada and put it in the transit (fingers crossed) :)
Cheers Mike
MWOOLY10
