injectors
injectors
Postby crazyscoot » Sat Apr 15, 2006 6:55 pm
My van is the 85ps td. If i were to change my injectors to the 100ps versions, will it have more umph? If its the answer no, then would it have more umph if the pump was tweaked ie max speed + mid range? Or is it that it will need a different pump to be able to increase the pressure
Negative reality inversion
crazyscoot
Postby 100ps_drw_hicube » Sat Apr 15, 2006 7:05 pm
think you have to tweak the pump to suit :? not sure on epics but 76ps bosch pumps you just tweak to suit :)
100ps_drw_hicube
Transit Abuser!!
Postby crazyscoot » Sat Apr 15, 2006 7:21 pm
good point hicube, I converted my pump to a Manuel, so no epic :D And my pump is tweaked up a few notches, so was wondering if it would be beneficial to put the 100ps injectors you have in mine?
crazyscoot
Postby 100ps_drw_hicube » Sat Apr 15, 2006 7:26 pm
yes!!! if your already turbo'd and running a manual pump :D :D ...... speak to ryzman he has a td running blues on a manual setup apparently a lot better than a epic :? :lol:
100ps_drw_hicube
Transit Abuser!!
Postby crazyscoot » Sat Apr 15, 2006 7:29 pm
pm with a price then hicube
crazyscoot
