power steering bolt
power steering bolt
Postby bubble » Mon Apr 17, 2006 9:10 pm
hi i have a 120 swb 1999 transit and the long bolt on the power steering pump works loose any ideas how to keep the bloody thing in it is up as tight as it will go but works loose.richie
bubble
Postby Luke » Mon Apr 17, 2006 9:12 pm
what about a bit of threadlock :?: will that work :?:
Postby MrMPuk » Mon Apr 17, 2006 9:13 pm
Maybe try some thread lock on the threads.
Postby crazyscoot » Mon Apr 17, 2006 9:14 pm
thread lock from halfords, comes in a small red tube. or use a nylock nut (the ones with a plastic around the top of them). Could also use a (i forget the proper name) star washer.
Negative reality inversion
crazyscoot
Postby Nighthawk » Mon Apr 17, 2006 9:16 pm
That was a common problem
You can't add another nut to the end of it because of it's proximity to the pump pulley, but a liquid thread locking compound will sort it.
Transit.........Job done
Nighthawk
Postby bubble » Mon Apr 17, 2006 9:37 pm
yeh thanks guys will get thread lock cant put a nylon nut on as the nut is part of the pump assembly and not alot of thread left.
bubble
