really REALLY need some parts help guys..
Postby rottie_007 » Tue Apr 14, 2009 6:38 pm
got told (on here) OD rear oil seal was the same as a non OD box so bought one but found it was too small..
so this might be down to the gearbox being an oddity.. it looks like a type 9 and has a GKN overdrive unit on??
also does anyone know if the cambelt tensioner on the YORK 2.4 is still available anywhere as my local factor drew a blank?
1979 mk2 pre facelift CI campervan " Bessie Brown "
1994 Pug 405 est " George "
1998 pug 106 "Mildred"
rottie_007
Re: really REALLY need some parts help guys..
Postby sidspop » Tue Apr 14, 2009 9:27 pm
I hope I can be useful here to you. An oil seal is just that, an oil seal. Just because it says Ford on the bag don't mean it was made by them, so I would be tempted to try local bearing or gasket suppliers, look in yellow pages or google it, and see if an industrial seal supplier can help.
Obviously you will need to give them basic info such as i/d and o/d, and the depth of the seal.
You may have to search a little farther afield, like West Midlands, there's still lots of suppliers round here for this sort of stuff.
Andy
sidspop
Location: The Black Country (near to Brummagem, but not the same)
Postby rottie_007 » Tue Apr 14, 2009 10:14 pm
thanks Andy.
ill get the old one out tomorrow and ge tthe digital calipers on it...
rottie_007
Postby greg123 » Wed Apr 15, 2009 12:54 am
There may well be part/mfr numbers on it, you can do a web search/get a supplier to match up. Measure the casting, not the oil seal, other than the depth.
Greg.
rottie_007 wrote:thanks Andy.
Independant VW/Audi Vehicle Engineer, qualified 18 years (tdi & vegoil specialist)
Ex IT tech, former IT Support manager, Webmaster
Occasionally return to London as a SIA Security Instructor & consultant!
greg123
Postby madmark » Wed Apr 15, 2009 1:38 pm
rottie the overdrive was used on mgb cars volvo,s etc it is called a laykock model J
i also have a leaking seal but its not that bad yet! :wink:
Postby nigelbarnes » Wed Apr 15, 2009 6:25 pm
I have been looking at a similar problem on mine. As madmark said, it is a laycock type J.
This overdrive was fitted to many sixties cars, and I have found parts drawings, part numbers and prices on the Rimmer Brothers website under Triumph Stag parts.
nigelbarnes
Postby rottie_007 » Wed Apr 15, 2009 6:44 pm
mines emptying the gearbox in a couple of hundred miles !!!!!!!!!!
rottie_007
Postby madmark » Thu Apr 16, 2009 1:37 pm
wow yours is bad ,you need a gearbox place or somebody who recons overdrives, i am trying to think of somebody ! :?
Postby rottie_007 » Sat Apr 25, 2009 11:17 pm
well as soon as I get the york timed up properly (teach me to not payheed to the original belt fitment) I will refit the rear flange and run it up just to make sure it IS coming from the rear and not from the body of the OD itself..
rottie_007
Postby madmark » Sun Apr 26, 2009 11:38 am
i oftern find with yorks and di,s its best to time them by ear! sometimes you set them at what they should be and they are horrid! :roll:
Postby manandvan » Wed May 13, 2009 9:32 pm
belt tensioner of 2.5 di is the same as your porkie :lol:
manandvan
Postby baconsdozen » Fri May 29, 2009 12:15 pm
Oil seals for the J type overdrive are available here.
http://www.overdrive-repairs.co.uk/spare_order_3.html
baconsdozen
Return to Mk 1 & 2
cron
