Lowering down the spare wheel!!
Postby matthew » Tue Apr 18, 2006 5:09 pm
Hi
Do you have to lower the spare wheel down If so what tool do you use as i know where it goes but seem to be missing the wheel brace but have the jack and the long hinged bit.
Matt
matthew
Postby MrMPuk » Tue Apr 18, 2006 5:10 pm
It's the end of the long hinged bit you use.
Postby matthew » Tue Apr 18, 2006 5:22 pm
is it. ive only got a half hook at one end for the jack and at the other is a full loop but that does not fit as it seem to have to be a long bar.
matthew
Postby Nighthawk » Tue Apr 18, 2006 10:00 pm
Is this on a standard van or a chassis cab?
if it's the Van, you need to use the actual wheel brace, stick the pointy end through the hole in the back bumper and turn anti clockwise to lower.
Chassis cabs are similar, but your long jack handle has a flat section to locate in the carrier winder.
Transit.........Job done
Nighthawk
Postby Lee J » Wed Apr 19, 2006 9:55 am
or do what I did and stick a chisel in there! I lost the jack and the wheel brace. :D
Transit Van - Gonna cost me a marriage if I'm not careful.
Lee J
Postby matthew » Wed Apr 19, 2006 10:35 am
i will give it a go, it need to be a long wheel brace as i have the rear bumper with the built in step.
matthew
Postby stevew » Wed Apr 19, 2006 12:57 pm
I remember having a huge struggle with this on our works van (MK6). As I recall it was possible to lower it slightly wonky and then it would catch on something and never get any lower. It's a bit vague i my memory but I think that we eventually got it out by winding it all the way back up as far as it would go and then carefully down keeping it straight.
EDIT: Now I remember. The wheel is held up under the van by both the cable and a safety catch. The catch is released by pushing the tool into the hole. BUT if the cable is lowered slightly without releasing the catch the it jams and cannot be released. This happens if someone tries to lower the wheel just using a srewdriver or something.
Good luck!
Steve
stevew
Postby matthew » Wed Apr 19, 2006 10:16 pm
thanks for all your help, i have mangaed to sort it out by buying a wheel brace with the end that fits the winder if you see what i mean, cost £10 but its all sorted now.......I think
matthew
Postby Gunslinger » Fri Apr 21, 2006 11:29 pm
nice to see its not just us with older vans that have spare wheel issues (and no surprise ford has managed to botch it again) ..... this is exactly why i fitted an LDV carrier to the rear of my mk2 :)
Gunslinger
