splitter?
splitter?
Postby monkey » Fri Apr 21, 2006 10:22 am
anyone have any idea where to find the splitter switch for the batteries?
i'm told that this device should isolate the main battery when the engine isn't runninig so i can start it when i've had the internal light on all night. is this correct? its a 92 lwb, high top
monkey
Postby AndyG » Fri Apr 21, 2006 10:26 am
Try a caravan/camper shop or even Fleabay :D
ooops
Postby monkey » Fri Apr 21, 2006 2:25 pm
sorry didn't make myself clear. i'm told there should be one on mine but i dont know where to find it as it seems to not be working
monkey
splitter ?
Postby Terry » Fri Apr 21, 2006 7:02 pm
Its a split charge relay, it is not fitted as standard, if you have a twin battery set-up you almost certainly have a split charge relay, but as an aftermarket item it could be anywhere.
Start by following the alternator wiring , red first .. somewhere probably under the dash you'll find a joined wire, follow that to a 'black-box' and that will (probably) be the split carge relay.
HTH
Pallet Puller
Terry
Postby MrMPuk » Fri Apr 21, 2006 7:36 pm
Having twin batterys doesn't always meaning a split charging relay.
Postby AndyG » Fri Apr 21, 2006 7:48 pm
MrMPuk wrote:Having twin batterys doesn't always meaning a split charging relay.
I can confirm that, as I have twins (batteries that is) and they work as one :D
It's a standard fitment on an Auto smiley :D :D
Postby Nighthawk » Fri Apr 21, 2006 9:51 pm
What you describe sounds more like a battery guard system.
That had a rocker switch fitted to the dash in the area around the steering wheel, when it sensed the voltage was getting close to a preset point where the engine will not start, a relay disconnected the main battery lead.
A quick press of the switch reclosed the system allowing the vehicle to start.
It was never a standard feature, but was widely adopted by many fleets.
Transit.........Job done
Nighthawk
