2.0 duratorq belt.
2.0 duratorq belt.
Postby mjm » Fri Apr 24, 2009 5:49 pm
hi all, need some help with the tranny, only used to the mk5. on way home tonight power steering went, followed shortly by the temp gauge rising, whats the belt arrangement on these, it a 2001 fwd 280 swb 2.0 duratorq, the belt thats snapped is the one on the right as you look from the front of the van, advice/ info much aprreciated, btw there was no warning.
mjm
Re: 2.0 duratorq belt.
Postby ake » Fri Apr 24, 2009 7:16 pm
Thats the auxilary drive belt, just get a new one on and all will be well again :)
Postby mjm » Fri Apr 24, 2009 7:19 pm
cheers for that, m8, i will go to motor factors in morning, thanks for quick reply.
mjm
Postby coconut » Fri Apr 24, 2009 9:12 pm
Check the tensioner pulley hasnt seized :!:
coconut
Ford Technician
Postby mjm » Sat Apr 25, 2009 1:09 pm
hi, been to ford dealer today and ordered both belts, are there only 2 belts on this engine, also the tensioner pulley is flapping about presumably this is why the belt has snapped, so looks like i will have to order one monday, the snapped belt only seems to drive the power steering why would this cause the van to overheat, also does anyone have a diagram so i know what im letting myself in for, and is it a pig of a job replacing the belt and tensioner pulley, regards, Mick.
mjm
Postby Dan T » Sat Apr 25, 2009 7:34 pm
mjm wrote:hi, been to ford dealer today and ordered both belts, are there only 2 belts on this engine, also the tensioner pulley is flapping about presumably this is why the belt has snapped, so looks like i will have to order one monday, the snapped belt only seems to drive the power steering why would this cause the van to overheat, also does anyone have a diagram so i know what im letting myself in for, and is it a pig of a job replacing the belt and tensioner pulley, regards, Mick.
This belt drives the water pump too :!: A spline goes from the PAS pump to the water pump.
Dan T
Postby mjm » Sat Apr 25, 2009 8:04 pm
cheers dan, do you know if its an awkward job to access tensioner and fit belt, what will need to come out to gain access, havent had a close look yet, mick.
mjm
Postby jacko1611 » Sat Apr 25, 2009 9:23 pm
can be a little awkward to get at, need to loosen off the egr pipe to get decent access to the belt and get the tensioner on
not another E G F*****G R!
jacko1611
Ford Technician
Postby mjm » Sun Apr 26, 2009 3:31 pm
update, got the old tensioner of today not as easy as i thought, what i would like to know is it false economy to just replace the pulley rather than the full tensioner, also im gonna change the alternator belt, is this a tensioner arrangement or does the alternator slide for adjustment, cheers, mick.
mjm
Postby coconut » Sun Apr 26, 2009 6:12 pm
The tensioner is easy, just do as jacko says and take off the egr support bracket and gently bend the pipe out the way of the bolt holding the tensioner on :wink:
The alternator belt is a stretchy belt (presuming you havent got A/C) cut the old one off then use the tool that comes with the new belt to feed it on :!:
coconut
Ford Technician
Postby mjm » Mon Apr 27, 2009 8:14 pm
van all done this afternoon, thanks for all advice guys.
mjm
Postby daxwax1 » Mon Apr 27, 2009 10:09 pm
they have stopped shouting i see :lol: :lol: :lol: :lol: :lol: :lol: :lol:
daxwax1
Postby jacko1611 » Tue Apr 28, 2009 6:34 pm
coconut wrote:The tensioner is easy, just do as jacko says and take off the egr support bracket and gently bend the pipe out the way of the bolt holding the tensioner on :wink:
wot does that word mean?
jacko1611
Ford Technician
Postby coconut » Wed Apr 29, 2009 7:28 pm
Use a small pry bar instead of a big one to bend it :)
coconut
Ford Technician
Postby ake » Wed Apr 29, 2009 7:32 pm
I'm sure gently means the 2lb hammer not the 4lb one :lol:
Users browsing this forum: knobby1
