Front spring hangers MK2
Postby karelwj » Sat Mar 14, 2009 10:32 am
Hello, i'm karel from the Netherlands and i am looking for:front spring hangers for my transit 1980 MK2.I understand that hangers of A MK3 also fits(with sam justifications)sombody ther kan help me?(sorry for my poor English)greats from Karel
karelwj
Re: Front spring hangers MK2
Postby cartooner » Sat Mar 14, 2009 10:49 am
Just sent a PM with a telephonenumber in the Netherlands.
cartooner
Postby redeemer » Sun Mar 15, 2009 2:14 pm
If you are skiled enough and have the right tools, then you can fabricate them from 1.5mm or greater sheet steel. First take out the outline on a piece of cardboard and then after cutting produce the lip on a vice. Here some of my pics. still have to do the other side :D
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Postby AndyG » Sun Mar 15, 2009 2:47 pm
redeemer wrote:If you are skiled enough and have the right tools, then you can fabricate them from 1.5mm or greater sheet steel. First take out the outline on a piece of cardboard and then after cutting produce the lip on a vice. Here some of my pics. still have to do the other side :D
8)
You make it look so easy :!: :!:
:wink:
Postby redeemer » Sun Mar 15, 2009 2:51 pm
:lol: :lol: :lol:
redeemer
Postby jerry2 » Wed May 06, 2009 8:26 pm
I have an extremley crusty and flaky front end .
My hangers are knackered too :oops:
Looks like good advice about the hangers as unable to track any down.
At the moment cutting front crossmember welding patches out and starting again so I will try fabricating these too.
Are they strong enough though?
jerry2
Postby Luke » Wed May 06, 2009 8:28 pm
Postby redeemer » Wed May 06, 2009 10:10 pm
My advice:
better if you find some mk3's as luke sugested
or
if you will fabricate them, I used 1.5mm sheet steel, and made the hanger from two sheets on one another spoted together.
If I will do it now , I would go for a single sheet perhaps 3mm or thicker, so to avoid having 2 sheets spotted together , between which moisture can form starting rust.
redeemer
Postby cartooner » Thu May 07, 2009 1:17 pm
They cost money, but are avialable:
http://www.oldcars.de/shop/index.htm?f= ... ic&exact=1
or:
No I still don't have any shares! :lol:
cartooner
Postby jerry2 » Sat May 09, 2009 9:51 pm
been quoted £38 each plus vat. Bit steep but only have to buy them once I hope (mk3)
jerry2
Postby redeemer » Sat May 09, 2009 11:06 pm
Make them yourself! They would be better out of 3mm sheet :idea:
redeemer
Return to Mk 1 & 2
